Continue
  • My Subscriptions
  • Events
PM8000 Firmware Upgrade
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PM8000 Firmware Upgrade
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
Bronco_G
Bronco_G
Explorer
Posted: ‎2026-04-23 02:54 PM
662
I need to upgrade firmware on a PM8000 from 1.000.057 to V1.088.0, so I then can upgrade to 2.1 and 3.1.  Is this older update available on the site somewhere? Can only find the later updates.
Charles_Murison
Champion
Posted: ‎2026-04-27 08:53 AM . Last Modified: ‎2026-04-27 08:53 AM
Hello @Bronco_G ,
You will need to reach out to technical support to get a copy of V1.4.3 firmware and V2.1.0 firmware. Upgrade to V1.4.3 first, Then upgrade to V2.1.0. V2.1.0 upgrade is a 2 step upgrade with V1.88.0 as first step.
Charles
Replies 4
Charles_Murison
Champion
Hello @Bronco_G ,
Charles
Cindy_Chui
Cindy_Chui Contributor
Contributor
Posted: ‎2026-10-07 04:12 AM
217
Hi @Charles_Murison , I have a PM8000 MID meter with version V001.001.000, is the correct upgrade path
Upgrade to V1.4.3 first then upgrade to V2.1.0 with the above  V2.1.0 upgrade is a 2 step upgrade with V1.88.0 as first step?
Is there anywhere I can download firmware V1.4.3?
Charles_Murison
Champion
Posted: ‎2026-10-07 07:16 AM . Last Modified: ‎2026-10-07 08:05 AM
1
213
Hello @Cindy_Chui ,
That is the correct upgrade path. V1.4.3 MID will need to be given by technical support. Please contact your local CCC to get the Upgrade file. Note that non-MID meter cannot accept MID firmware, MID meter cannot accept non MID firmware.
Charles
Cindy_Chui
Contributor
Posted: ‎2026-10-22 03:04 AM
thank you Charles
