Hello @joel_mora_soati ,
This issue may be device-specific and could require further investigation. We recommend arranging a call with our technical support team so that additional information and diagnostics can be reviewed.
Based on the observations and findings from the discussion, we will be able to provide more specific recommendations on the next steps.
Rohith S
Hello Joel,
Firmware upgrades may fail if communication between the device and server is interrupted during the upgrade process.
Please connect the device directly to the server and retry the firmware upgrade. Once the upgrade completes successfully, the device should return to normal operation.
This is the recommended recovery method at this stage.
Rohith S
L4 - Technical Expert
Hi @rohith-s,
Thanks for your answer.
We tried this several times with different computers and disabling other networks in the PC. Do you have any recommendations?
Best regards.
Thank you for your feedback. Please try upgrading the device using the firmware file only and do not use the language file during the process.
This should help recover the device and restore it to normal operating mode.
Rohith S
you ever get this resolved? We had similar glitch with a 5563RD, and haven't had the chance to get back out to retry as its not the most critical meter in that location. Was told similar to retry, but not sure if it just took ftp/sftp or what tool they used, or if it took using DLF3000.
Hello @rohith-s
Thanks for your answer. We did it as you mentioned but continue with the same result.
Regards
Hello @Brian_McKeon ,
The PM5563RD firmware can be upgraded using either the Firmware Upgrade Tool or the device web interface.
If you encounter an issue, please share a photo of the device display showing the error message, along with the device serial number and firmware version details.
In some cases, if the firmware upgrade process is interrupted or aborted, the display may show a "Waiting for Host" message. If this message persists even after a power cycle, the device may not be able to recover through standard field recovery methods. In such situations, device replacement may be required.
Providing the requested information will help in assessing the condition and recommending the appropriate next steps.
Rohith S
Rohith S
Hello @rohith-s,
Thank you for your response.
Could you please advise us on the appropriate process to schedule a call with the technical support team? We would appreciate your guidance on the fastest and most effective channel to coordinate the session and ensure that the case is reviewed promptly.
Please let us know whether the call should be arranged through this support case, by email, or through another scheduling platform. We are available to provide the required logs, firmware details, photographs, and any additional information in advance so the technical team can review the case efficiently.
