PM5000
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Re: PM5000
Charles_Murison
Charles_Murison Champion
571
Mehran_Mehrnia
Mehran_Mehrnia Champion
202
Ramasamy_N
Ramasamy_N Champion
115
Gladwin
Gladwin Contributor
Contributor
Posted: ‎2025-03-03 06:52 AM
858
PM5000
Good day Team,
hope you can assist me.
I'm experiencing an issue with the PM5560; it keeps resetting or changing its IP address.
I have two units: one is functioning properly, while the other is having IP address problems. The working unit is on firmware version 02.07.8, whereas the faulty one is on 04.03.2.
could this be a firmware issue ?
Thank you
Best regards,
Nikolaj_Johansen_Retired
Leader
Posted: ‎2025-03-03 08:10 AM
Hi!
I would update the firmware on that device, as I know there I a hotfix available 4.3.3 for your firmware version 4.3.2
there is also a newer firmware available 4.4.5. You Can se in the firmware downloaded ZIP file “Firmware upgrade user manual snippet” how to update.
Regards.
Nikolaj Johansen
El-Tek Automation ApS
EcoXpert Partner: Certified Critical Power
Reply 1
Leader
Hi!
Regards.
Nikolaj Johansen
