Continue
  • My Subscriptions
  • Events
PM2000 - Negative parameter in the Lower Limit field for analog module
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PM2000 - Negative parameter in the Lower Limit field for analog module
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
HellZet
HellZet Explorer
Explorer
Posted: ‎2025-12-19 02:20 AM
766
Greetings guys,
We have potential project with PM2000 and METSEPM2KANLGIO22. And we need to understand a configuration of analog module. Can I put for example negative parameter for lower limit? Because I couldn't test it by myself without physical device in ION setup.
Also, maybe we have some tricks to work with ION setup without physical device?
Thanks in advance.
  • iEM2000
  • PM8000
Mehran_Mehrnia
Champion
Posted: ‎2025-12-19 07:29 AM
1
763
Hi @HellZet
Yes, you can set negative values for the engineering scale (Lower Limit), but the physical output remains positive such as 4-20mA.
There is no offline device configuration feature in ION Setup for PM2000.
Best Regards,
-Mehran
L3 Expert Advanced metering
Mehran_Mehrnia
Champion
1
763
Hi @HellZet
Best Regards,
-Mehran
HellZet
HellZet Explorer
Explorer
Posted: ‎2025-12-22 06:08 AM
@Mehran_Mehrnia Thanks
