Can someone share a sample program using Control Expert GPL communicating M580 and METSEPM8240. We are having trouble communicating. We are able to read the power meter and grab the data from it using normal communication means (ReadVar). Once I use the GPL block, I get no data from the meter
The function block was identified as needing a revision. It has been escalated to engineering and a new function block will be produced.
Since READ_VAR is successfully retrieving data from the PM8240, I assume the underlying Modbus communication is working correctly. The issue is therefore more likely related to the GPL block configuration. I would recommend posting the question in the Modicon PAC Community Forum.
Best Regards,
-Mehran
L3 Expert Advanced metering
Hello @SaulEspinoza ,
I do not know the M580 devices so I cannot speak to this. Does the device support RSTP? Is there a reason to connect both Ethernet cables? Perhaps if not using RSTP having both connected could be causing trouble
Charles
