Is it possible to modify reports in Setup Assitant?
Metering & Power Quality
Select a Country
  • EcoStruxure Power & Grid
  • Is it possible to modify reports in Setup Assitant?
Charles_Murison
Charles_Murison Champion
566
Mehran_Mehrnia
Mehran_Mehrnia Champion
194
Ramasamy_N
Ramasamy_N Champion
115
PowerLogic
PowerLogic ION7400 series
Veronika.Salinas
Veronika.Salinas
Contributor
Posted: ‎2026-04-28 06:39 AM
221
Hello everyone,
I would like to know if there is any way to edit the available reports of an ION meter within the Reports section of Setup Assistant (ION Setup). I understand that modifications can be made through the Data Recorder modules in advanced mode and editing the files of the data recorders' archive; however, my client specifically needs to define or customize the reporting time period directly in the generated reports, and asked us to add some reports to the available list.
Any guidance or recommendations would be appreciated.
Thank you in advance for your support.
Best regards.
  • Thumbnail of PowerLogic ION7400 series
    PowerLogic
View products (1)
  • ION7000
Mehran_Mehrnia
Champion
Posted: ‎2026-04-28 07:26 AM
Hi @Veronika.Salinas
Please check the similar recent post regarding how to add more reports to the default list of Setup Assistant → Reports:
How to add additional logging sheets visible in Setup Assistant → Reports
Best Regards,
-Mehran
L3 Expert Advanced metering
Mehran_Mehrnia
Champion
Best Regards,
-Mehran
