Continue
  • My Subscriptions
  • Events
ION Setup 3.2 and PM2230 auto reset calendar
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Re: ION Setup 3.2 and PM2230 auto reset calendar
Charles_Murison
Charles_Murison Champion
581
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
David_Kwan
David_Kwan
Explorer
Posted: ‎2026-09-17 08:02 PM
270
When using ION setup to config the auto reset calendar in PM2230, when I choose the date to be reset and press ok, the reset calendar suppose to show the date I chosen, instead, it show a pile of meaningless character, and as expected, the command could not download to PM2230.
Is it a software bug? How to deal with it?
  • ION Setup
akash_das
akash_das Troubleshooter
Troubleshooter
Posted: ‎2026-09-25 02:31 AM
Hello @David_Kwan
This appears to be a defect in ION Setup. Could you please create a support ticket so that the issue can be investigated and addressed by the development team?
In the meantime, as a workaround, you can configure the Auto Reset Calendar using the available Modbus registers. Auto Reset for Energy and Maximum Demand parameters can be configured only
through communication.
Replies 2
Charles_Murison
Champion
Posted: ‎2026-09-18 08:58 AM
Hello @David_Kwan ,
Please contact your local customer care center (CCC) to start a case. If this is an unexpected behaviour the development team will need information from the case.
If possible, are you able to record the packet traffic from the computer to the meter? For example using Wireshark. If possible, be sure to include the capture when you contact the CCC.
Charles
akash_das
Troubleshooter
Hello @David_Kwan
