Continue
  • My Subscriptions
  • Events
ION Meter SSO (Subsynchronous Oscillation) Module comments and bugs
Metering & Power Quality
  • EcoStruxure Power & Grid
  • ION Meter SSO (Subsynchronous Oscillation) Module comments and bugs
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
eRicC
eRicC
Explorer
Posted: ‎2026-08-07 04:02 AM . Last Modified: ‎2026-09-10 08:49 PM
846
Hi there,
Upon the setup of new SSO module, there are several comment and clarification.
Background
  • We have setup Data Recorder module to capture the SSO Module's output
  • The SSO module has defined frequency group
Comments and Clarifications
  1. Once the SSO New Update Available count number reaches 65535, no more trigger pulse would be sending.  That looks like a bug and probably need to fix.
  2. We have setup the Data Recording Module to record all 10 groups of SSO Peak Frequency & Magnitude as well as the self-defined Frequency Range to understand the SSO module operation.
    As shown below, the SSO1 Peak 1 Frequency captured several incident of 0-0.5Hz SSO event with magnitude stated in light blue.  We have setup the Frequency Group 0-0.5Hz (column name FqGp_0.0,0.5) as well but there is a discrepancy of magnitude as illustrated as orange column below.
    Understood that the SSO1 Peak 1 indicates the max incident with magnitude at specific frequency.  The frequency range would be calculated across the entire range, but given the fluctuation of discrepancy, how is the aggregation of the module? Is that an averaged magnitude of all detected SSO within the self-defined frequency range? Or otherwise please advise?
  1. Same as MQTT module and unlike all the other existing modules, wondering why there is no longer an Enable Input allowing the flexibility to disable the module temporarily or enable the module under specific logical conditions.
  2. (Identified on 11 Sep 2026)
    All Frequency Groups would return NULL value (n/a) after power cycling the meter.   eRicC_0-1789098490958.png
    That could not be fixed until a manual update of Frequency Groups' setup register (a real change of setup register value and send to meter).
Thanks.
  • ION7000
  • ION9000
  • PM8000
Tags (3)
  • sso
  • Subsynchronous Oscillation
Charles_Murison
Champion
Posted: ‎2026-10-16 03:54 PM
Hello @eRicC ,
V4.7.3 addresses the observations you have reported. SSO pulse output and the frequency groups after power cycle.
See post on V4.7.3
Charles
Replies 8
Charles_Murison
Champion
Posted: ‎2026-08-07 09:01 AM
Hello @eRicC ,
I know that this was also a case with Technical support. Will confirm details through the case and update here if there is specific information that can be shared.
Charles
Charles_Murison
Champion
Posted: ‎2026-08-11 09:40 AM
5
775
Hello @eRicC ,
Regarding point 1, there could be a work around but does require a few additional modules to achieve. Ideal would be to have a frequency group that is a large range however I believe you are using all 50 groups in your configuration. Will need to select a frequency group that has as large a range as possible or known to have a changing value.
Will need a new periodic timer module that is set to 1/2 cycle. Will need a new differentiator module, the trigger input is linked to the new periodic timer module, the source is linked SSO frequency group. This way the differentiator module will be 0 most of the time then for 1 half cycle have a non zero value. The output from the differentiator will need to be linked to a convert module. Link the On pulse of convert module to the input of the data recorder module.
Regarding point 2, will need to confirm with the team. All I know for sure is that the aggregation is for all peaks that exceed the threshold that fall within the defined frequency group.
regarding point 3, the assumption has been than once configured, user would not want to disable the module.
Charles
Charles_Murison
Champion
Posted: ‎2026-08-11 12:15 PM
Update for Point 2, the frequency group is aggregating all the spectral content within the defined frequency range not peaks.
eRicC
eRicC
Explorer
Posted: ‎2026-08-11 05:25 PM . Last Modified: ‎2026-08-11 05:25 PM
763
Hi @Charles_Murison
Thanks for the workaround.
Would the use of differentiator module fall in a scenario when two or more consecutive Change of Value events happen such that failed to let convert module to reset or resend the trigger pulse given the output would be stayed in non-zero value.
Would it sound more robust to have a store module (linking to the same periodic timer module) recording the same Frequency Group magnitude as "Previous Records" and followed by using Relative Setpoint Module to compare the change of New and Previous Records then send a trigger pulse / convert module.  (That logic would sound like the feature in Arithmetic Module (but that only for non-HS) to compare previous records).
Happy to discuss.
Charles_Murison
Champion
Posted: ‎2026-08-13 04:00 PM
723
Hello @eRicC ,
I am not sure how your solution would be more robust than what I suggested. The SSO module is a little different than all other ION modules in that the output is approximately once a second but not running within the one second task like other modules.
Differentiator module would be running high speed so module would be 0 until there is a change at the output of SSO.
Charles
eRicC
eRicC
Explorer
Posted: ‎2026-09-10 08:46 PM . Last Modified: ‎2026-09-10 08:49 PM
453
Hi @Charles_Murison
Thanks and do understand the benefit of using Differentiator module which could reduce the use of modules compare to my solution.
From the recent test I would suggest a fine tuning of linking that to the Peak1 Frequency / Magnitude instead of a Frequency Group because a new bug is found - all Frequency Groups would return NULL value (n/a) after power cycling the meter.
And that could not be fixed until a manual update of Frequency Groups' setup register (a real change of setup register value and send to meter).
I have tested twice and confirmed this behaviour.
With all the bugs identified, there is a necessary of releasing a firmware update.
Charles_Murison
Champion
Posted: ‎2026-09-11 09:41 AM
Hello @eRicC ,
I have reported this new behavior to the firmware team. When I have an update to provide I will update this post.
Charles
Charles_Murison
Champion
Hello @eRicC ,
See post on V4.7.3
Charles
