High Speed ION Module - ION 9000
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Re: High Speed ION Module - ION 9000
Charles_Murison
Charles_Murison Champion
571
Mehran_Mehrnia
Mehran_Mehrnia Champion
202
Ramasamy_N
Ramasamy_N Champion
115
jonathanzamban
jonathanzamban
Explorer
Posted: ‎2020-09-29 03:16 AM
1697
I am looking to change the update rate of the High Speed ION Modules on one of the ION 9000s that I am working on. By default it updates the readings every half of a cycle (10ms) and I am trying to set it at 20ms. Is it possible? How do I change this?
Thank you,
Jonathan.
Charles_Murison
Champion
Posted: ‎2020-09-29 09:53 AM
1
1690
Hello @jonathanzamban ,
The ION module speeds are either high speed (half cycle) slow speed (1 second) or event driven. There is no way to select an update rate. What module are you working with and why do you want the update to be every 20 ms?
Charles
Replies 2
Charles_Murison
Champion
1
1691
Charles
jonathanzamban
jonathanzamban
Explorer
Posted: ‎2020-10-05 03:23 AM
Hi @Charles_Murison,
Thanks for clarifying.
I am testing a framework with the High-Speed measurements (Voltage, Current, Frequency, etc.) and I am looking to log them for a short period with 20ms space between each log.
But, I will try to overcome this with a 20ms timer trigger for each record.
Thanks for your help,
Jonathan.
