Gate drive trip error pcs+
Metering & Power Quality
Send InviteCancel
2026-01-2308:44 AM
Hi, I hope everyone is having a good day. Recently, I commissioned an Accusine PCS+ filter, but I encountered an error message stating that the contactor has not closed. After investigating further, I found that the gate drive filter has tripped. I believe the contactor issue might be resolved once the gate drive trip is corrected, but I am not sure how to proceed. Any information about this error or guidance on how to address it would be greatly appreciated.
2026-10-2208:46 PM
Hello Camilo, Sorry, just saw your topic. Yes, your understanding is right. I recommend checking the wiring connections at J17 and J18(white color) on the control board. Please unplug and reconnect the connectors, making sure that they are firmly and securely connected. Then, follow the cables from J17/J18 to the IGBT driver board and check the connections at the three connectors. Please make sure that all connections are secure.
After confirming that all connections are correct and secure, power up the unit again and check whether the problem has been resolved.
If the problem still persists, I recommend swapping the IGBT driver board with the one from another unit to check whether the issue follows the driver board. BRs
2026-10-2208:46 PM
