Continue
  • My Subscriptions
  • Events
Discrepancy in current readings between PowerTag and PQ Meter
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Discrepancy in current readings between PowerTag and PQ Meter
Charles_Murison
Charles_Murison Champion
581
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Stuart_Cheng
Stuart_Cheng Contributor
Contributor
Posted: ‎2026-05-05 08:50 AM . Last Modified: ‎2026-05-05 08:52 AM
638
Hi All,
I am experiencing a discrepancy in current readings on the VSD (ATV212HD15N4).
In standby mode, the PowerTag (A9MEM1570) reports higher current values compared to Hioki instruments.
Standby Mode Comparisons:
  • PowerTag: 2–4 A
  • Hioki Clamp Meter: 0.8–0.9 A
  • Hioki PQ Analyzer: ~0.95 A
When switched to bypass (CB directly to contactor), the PowerTag reading drops to 0 A, indicating the abnormal readings are related to the VSD.
However, opposite results were observed in operation mode; the PowerTag shows lower current values than the Hioki meters.
Operation Mode Comparisons:
  • PowerTag: 16–19 A
  • Hioki Clamp Meter: 23–24 A
  • Hioki PQ Analyzer: 23–24 A
Does anyone have similar experiences and know how to explain this situation? Thank you.
  • PowerTag Energy
Charles_Murison
Champion
Posted: ‎2026-06-08 01:30 PM
Hello @Stuart_Cheng ,
If you are still having strange behavior, please reach out to your local technical support to start a case to troubleshoot.
Charles
Thierry_Baudard
Thierry_Baudard Champion
Champion
Posted: ‎2026-05-06 07:37 AM
Hi @Stuart_Cheng
A PowerTag is designed to be installed only on a 50/60 Hz electrical network, within the voltage range specified in the product documentation.
A variable speed drive adjusts both frequency and voltage to control motor speed. As a result, it is very likely that PowerTag measurements will be inaccurate if the PowerTag is measuring currents on the output side of the drive (although I do not know whether this applies to your installation).
I would also like to emphasize that, as stated in the PowerTag instruction sheet for reference A9MEM1570 (doc QGH70), a PowerTag must never be installed downstream of a variable speed drive, as this may cause excessive overheating, potentially leading to its destruction.
Thierry BAUDARD
EcoStruxure Power- Technical Support Expert for Softwares & Solutions
Stuart_Cheng
Contributor
Posted: ‎2026-05-06 07:59 AM
617
Hi @Thierry_Baudard,
Thanks for your reply and apologize for not making it clear earlier. We installed PowerTag upstream of the VSD, but still encountered an issue, which is the strange part.
Charles_Murison
Champion
Charles
