Can't access CM2250 settings/config
Metering & Power Quality
Send InviteCancel
2026-04-1309:03 AM
We wanted to swap out our CM2250 and CM150 power monitors with some PM5560's. I wanted to verify the settings on the CM2250 but following the instructions here https://www.se.com/us/en/faqs/FA218954/ doesn't work because mode will only cycle through Alarm and [Setup]. When in setup it only cycles through [Address] and [Baud Rate]. I've watched Youtube videos and they all pretty much follow the same instructions as the link I posted.
The alarm LED is flashing and 991 is displayed when alarm mode is activated, maybe that would be a problem? I can't imagine it would limit access to the configuration. I don't see any alarm codes listed in the Powerlogic CM2000 Circuit Monitor Instruction.pdf that I have on hand.
