LayoutFAST User Group Forum
The LayoutFAST User Group is a place where Specifiers, Contractors, and Panel Builders share their User experience with the tool and ask Schneider Electric experts questions to solve their issues.
Posted: 2020-11-18 10:38 AM . Last Modified: 2021-11-03 09:39 AM
LayoutFAST is compatible with Revit 2018 to Revit 2022.
(edited to reflect currently supported versions)
Posted: 2020-11-25 02:12 PM
We just published the new version of the LayoutFAST Plug-In for Revit which is compatible with Revit 2021. You can download and install it here:
Posted: 2020-11-20 11:43 AM
@jeffweidner Do you have an approximate date range for when LayoutFAST will be compatible for Revit 2021?
Posted: 2020-11-20 02:01 PM
Support for Revit 2021 has already been developed but is being validated by QA/test. I expect it will be released and available for download by December 11th. Perhaps earlier.
BTW - the new version of the LayoutFAST plug-in requires .Net 4.8 which can be downloaded and installed here:
https://dotnet.microsoft.com/download/dotnet-framework/net48
Posted: 2021-04-15 10:17 AM
Hi Everyone, just an update to Jeff's answer above: As of April 2021, LayoutFAST is now compatible with Revit 2018 through Revit 2022! I should mention, however, we are discontinuing support for Revit 2017 and earlier. The reason why is that AutoDesk itself does not support versions that are beyond 5 years prior to their latest version. Since Revit 2022 is out right now, we will follow suit.
