82514members
350118posts
Wrong result in Machine SCADA Expert SQL query.
jthyge
Hello
I am making a SQL query to a MySQL database.
When I run the query in MySQL, I get the right result.
When I send the SQL statement from Machine SCADA Expert, the result is not right.
It is like the lase WHERE clause is ignored.
This is the Query:
SELECT SUM(Minute_In_State) From
   (SELECT
   Time_Stamp,
   State,
   TIMESTAMPDIFF(SECOND, LAG(Time_Stamp) OVER(ORDER BY Time_Stamp), Time_Stamp)
   AS Minute_In_State
   FROM db.xyz_1_state
   ORDER BY Time_Stamp) AS T
Where State = 1;
Any suggestion why the result is different, when sent from Machine SCADA Expert?
BevanWeiss
Spock
Spock
905
Re: Wrong result in Machine SCADA Expert SQL query.
This is the Geo SCADA Expert forum.  So you're not that likely to get great results looking for Machine SCADA Expert info here (since they are different products).
I think you wanted this forum instead: https://community.exchange.se.com/t5/Industry-Automation-and-Control/bd-p/industry-automation-contro...
2 Replies 2
BevanWeiss
Spock
Spock
906
jthyge
Oh Ok.
Thanks!!
