82545members
350156posts
Tags in SQL statements?
jthyge
1696
Hello
How is it possible to use tags in SQL statements in Machine SCADA Expert?
If I e.g. want to change the database the select is made in.
SELECT * FROM [TAG].trend001
Best regards
Jesper
Paul_Derbyshire
Ensign Ensign
1
1673
Re: Tags in SQL statements?
Hell Jesper,
You can use {} to enclose tags in a DBExecute script command.
For example:
SELECT * FROM {MyTag}.trend001
However, you want to change the database?
You can change the database/ERP reference in the DB Execute.
$DBExecute($MyDBConnection, "SELECT * FROM trend001")
Where $MyDBConnection is a string which contains the of the Database/ERP connection name that you created.
@jthyge wrote:
Hello
Best regards
Jesper
Paul Derbyshire
Senior Product Application Expert | Sales Enablement | HMI Line of Business, Digital Factory | Industrial Automation Business | Schneider Electric
4 Replies 4
Rodrigo_Garcia
Hello @TomDroll , Could you support on this?
Rodrigo G.
Industrial Automation Community manager
Paul_Derbyshire
Ensign Ensign
1
1674
Hell Jesper,
For example:
@jthyge wrote:
Hello
Best regards
Jesper
Paul Derbyshire
TomDroll
Lt. Commander Lt. Commander
HI,
Yes it is possible to add tags to your SQL query. there are 3 options available.
Option 1:VB Script or Function where you can use VB Variables to build the query and then the $DBExecute function. something like this:
Dim SQL
SQL = "SELECT FROM Table WHERE Column = " & $TagName
$DBExecute("Connection",SQL)
Option 2: You can also use the script database command $DBSelect command with the syntax below.
DBSelect("DB1","Table1","Array1,Array2","Column1,Column2","","")
Option 3: You can use the database worksheets in the Tasks->Database/ERP folder,  the condition field would be your select where from would be.
Hopefully this helps!
Tom Droll
jthyge
Thanks Paul  and Tom
This was just what I was looking for.
