We Value Your Feedback!
M171 can't write value as Modbus Master
  • Industrial Automation
  • Re: M171 can't write value as Modbus Master
Bastian_Schmitz
Admiral Bastian_Schmitz Admiral
32
LeTomas
Lt. Commander LeTomas Lt. Commander
12
RoozeeR
Lt. Commander RoozeeR Lt. Commander
6
JerryBartlemay
Lieutenant JG JerryBartlemay Lieutenant JG
6
Back to Industry Automation and Control Forum
summersiu
Lieutenant | EcoXpert Master summersiu Lieutenant | EcoXpert Master
Posted: ‎2021-03-24 01:42 AM . Last Modified: ‎2021-03-24 07:33 PM
2392
I am connecting my M171PBM27R (Act as Master) and my PC act as Slave to transfer value.
However, after I created function 06 and assigned "test1" into it, I still cannot change the value in Watch View.
(For example, I want to change 4 to 5 into Watchview and I can observe the change in Modbus Slave
The value will be auto change back. How can I change the value in Machine Expert?
Problem solved😁
  • Smart Design & Engineering
  • SoMachince HVAC
Dave_Shore
Dave_Shore Schneider Alumni (Retired)
Posted: ‎2021-03-24 02:47 AM . Last Modified: ‎2022-10-19 01:49 AM
In response to summersiu
@summersiu
I am not familiar with the Machine Expert product, but I found
https://community.se.com/t5/b-ecostruxure-geo-scada-expert-forum/EcoStruxure%2525E2%252584%2525A2+Ma...
Home/Communities/SCADA & Telemetry Solutions/Geo SCADA Expert Forum/EcoStruxure(TM) Machine Expert - HVAC
I have often used Modbus Slave, ModPoll, ModScan etc and all work with EBO.
You could test Machine Expert using EBO (the AS is easily configured to work with Modbus RTU/RS485), but ModSlave should also work fine and may be better for simple testing.
Replies 3
Dave_Shore
Posted: ‎2021-03-24 02:05 AM
2389
Hi @summersiu
Your question does not seem to involve EBO (this forum), It seems to be Machine Expert (M171?) to Modbus Slave
Is there a forum for the product you are using?
summersiu
Posted: ‎2021-03-24 02:28 AM
In response to Dave_Shore
2387
@Dave_Shore May I know where I can ask question for Schneider Machine Expert?
Dave_Shore
@summersiu
This is a heading
