KB - EcoStruxure Machine Expert - M660 - Edge IO NTS - CAM Switch Configuration
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
Select a Country
  • Industrial Automation Knowledge Base
  • KB - EcoStruxure Machine Expert - M660 - Edge IO NTS - CAM Switch Configuration
  • Lrhaouch
    Lrhaouch
EcoStruxure™ Machine Expert
Back to Industrial Automation Knowledge Base
Lrhaouch Explorer
‎2026-05-08 04:27 AM
on ‎2026-05-08 04:27 AM
In high-speed motion control applications, using standard PLC logic to activate digital outputs based on an axis's position can introduce scan-time latency, resulting in delayed and inaccurate machine timing.
Implement a CAM Switch configuration utilizing the Modicon M660 Motion Controller and the Edge IO NTS Motion Module in EcoStruxure Machine Expert Logic Builder. This configuration maps precise hardware-level position tracking to deterministic output modules.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
  • High Performance Machine Control
Rate this article:
