Continue
  • My Subscriptions
  • Events
EcoStruxure Machine Expert - Modicon M660 EtherCAT Master with LMC EtherCAT Slave
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Machine Expert - Modicon M660 EtherCAT Master with LMC EtherCAT Slave
  • Lrhaouch
    Lrhaouch
EcoStruxure™ Machine Expert
Back to Industrial Automation Knowledge Base
Lrhaouch Explorer
‎2026-10-21 06:08 AM
on ‎2026-10-21 06:08 AM
How can a Modicon M660 controller exchange cyclic process data with a PacDrive LMC controller over EtherCAT, with the M660 as EtherCAT master and the LMC as EtherCAT slave?
Configure the LMC as an EtherCAT slave in EcoStruxure Machine Expert, define its I/O channels and generate its ESI (XML) file. Install this file in the Device Repository of the M660 project, then add the LMC as a slave under the M660 EtherCAT master to exchange process data cyclically. Note that the M660 EtherCAT master currently supports EtherCAT I/O devices only; drives and motion devices are not supported.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
  • Communication
Rate this article:
(1)
