Continue
  • My Subscriptions
  • Events
EcoStruxure Expert Expert - Configure LXM32S as Sercos Drive with M660
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Expert Expert - Configure LXM32S as Sercos Drive with M660
  • Lrhaouch
    Lrhaouch
EcoStruxure™ Machine Expert
Back to Industrial Automation Knowledge Base
Lrhaouch Explorer
‎2026-05-06 01:20 PM
on ‎2026-05-06 01:20 PM
Users need to properly add and configure an LXM32S drive so it can communicate and operate over a Sercos network controlled by a Modicon M660 Motion Controller within EcoStruxure Machine Expert
To integrate the drive, add a generic "SERCOS Drive" to the SercosMaster node and change its working mode to "Physical". Update the generic Sercos identification by setting the Vendor Device ID to "LXM32" and the Vendor Code to "1". Finally, configure the scaling by setting the Increment Resolution to "131072" (matching the drive's default). Once downloaded to the controller and the Sercos state reaches Phase 4, the drive can be operated using standard PLCopen Function Blocks
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
  • High Performance Machine Control
Rate this article:
