problem with MPR-5610-704-0-4
HVAC and Pumping Forum
Send InviteCancel
Posted: 2026-08-2102:29 PM
Hello everybody.
Im using MPR-5610-704-0-4 with an eurotherm 3216 controller. i replace the actuator with the MPR-5610-0-0-4 and i realize the actuator is on all the time, but i put back the MPR-5610-704-0-4 actuator and is working fine. Both actuators looks like work from 4-20 mADC, but with MPR-5610-704-0-4 you can see the actuator moving back and forth, but with MPR-5610-0-0-4 eurotherm 3216 seens is not working. Both valves are working under the same controller
