Unable to use energy trend from application library
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Unable to use energy trend from application library
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
Yatin3
Yatin3
Contributor
Posted: ‎2025-12-19 10:10 PM
383
How to link expression
it is giving error if I connect tag with ADR() expression.
  • HVAC
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2025-12-23 12:14 AM
an expression can be connected only to an input pin of a block.
Yatin3
Yatin3
Contributor
Posted: ‎2025-12-24 02:03 AM
Then how to connect a variable on ptrarr_consummonthy pin with array of INT. ??
FedericoM
FedericoM Mentor
Mentor
Yatin3
Yatin3
Contributor
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2025-12-31 12:48 AM
define a variable ptrReal of type @REAL and assign it to the output pin.
@ptrReal gives the value of the first location of an array of 12 elements
ptrReal := ptrReal + 4;
allows to move to the next location
