TM172SIG retain variables
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • TM172SIG retain variables
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
Szekeres_ADE
Szekeres_ADE Explorer
Explorer
Posted: ‎2026-05-11 04:51 AM
470
I am writing a program for TM172SIG.
I need some variables to retain their values ​​in case of power failure.
How can I do this?
Thank you:
Zsolt
@retain variable
  • Connectivity
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2026-05-15 02:35 AM
445
the RETAIN area of TM172SIG is stored into flash on variation with the following rules:
If your retain data change continously it will be really saved once per minute, but you will damage soon the Flash.
The RETAIN area of TM173O is instead saved at power off, TM172 has a DWORD retained by lithium battery.
Do you have only TM172SIG in your architecture?
Replies 4
FedericoM
FedericoM Mentor
Mentor
446
Szekeres_ADE
Explorer
Posted: ‎2026-05-15 03:47 AM
In response to FedericoM
Hello Federico,
Yes, there is only a TM172SIG in the architecture.
I collect some machine running signal, make working hours, and send hours and minutes end of the day in email.
I like to save the datas i the reatin memory every minutes.
So my  update time 60s.
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2026-05-18 01:25 AM
400
It is better to save working hours into flash every hour
Szekeres_ADE
Explorer
Posted: ‎2026-05-19 07:47 AM
Dear Federico,
Thanks for the help.
I'll keep an eye on the timing.
