Continue
  • My Subscriptions
  • Events
TM172 HMI Control outside of page
HVAC and Pumping Forum
  • Industrial Automation
  • HVAC and Pumping Forum
  • Re: TM172 HMI Control outside of page
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
otrotabi
otrotabi
Contributor
Posted: ‎2025-07-26 03:53 AM . Last Modified: ‎2025-07-26 06:23 AM
1142
I threw in a static control associated with a set in a page (actually a message page). The size of the static control did not fit the screen right so I moved it with my mouse, and then the control became unavailable, it is actually outside of the screen. So what happens is that I can not select it again to put it back into a visible position. Or delete it.
I get this warning: PG:AlarmMessage - warning V2371: => The page contains controls outside the page size
 Other than starting over and creating a new page is there any solution to this ?
  • HVAC
  • ecostruxure
  • hvac
  • TM171
  • TM172
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2025-08-01 07:02 AM
If it happens, the issue must be fixed manually by opening the file .pagx in the HMIremote folder.
Looking for a negative xPos or yPos
Replies 3
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2025-07-27 11:47 PM
If you share this project (or a copy without Programming part), I can have a look at it
FedericoM
FedericoM Mentor
Mentor
otrotabi
otrotabi
Contributor
Posted: ‎2025-08-01 08:31 AM
