SpaceLogic TC900 thermostat write register FC06 with Modbus Modicon M172
HVAC and Pumping Forum
Send InviteCancel
Posted: 2025-10-2203:29 AM
How can I write some modbus register (eg: setpoint) to the thermostat TC903 using function code 06 with M172 using EcoStruxure™ Machine Expert - HVAC version 1.7? The PLC writes using function code 10 (16d), but the thermostat only accepts function 06 (I used a template created with ModbusCustomEditor). Write functions are no longer available in the applications, and applications created with version 1.4 give a compilation error in version 1.7.
