Secure Interface Gateway - sending email
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Secure Interface Gateway - sending email
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
KrzysztofSoczewka
KrzysztofSoczewka
Contributor
Posted: ‎2026-07-16 04:42 AM
234
We tested the following code using Gmail SMTP. A 16-character Google App Password was generated and entered as Server_Password. However, the controller still does not send the email, function not return an error, but the email is not received.
VAR
sendMail : BOOL := FALSE;
sendMessage : Email_SendMessage;
res : Email_Errors;
END_VAR
We used:
SMTP server: smtp.gmail.com
Port: 587
Authentication: Auth_Login
TLS: TRUE
STARTTLS: TRUE
Password: Google App Password
The actual Google App Password should not be shared for security reasons.
  • HVAC
williamFolle
williamFolle Contributor
Contributor
Posted: ‎2026-07-17 02:27 AM
1
212
Hello, looking at the settings you sent, I’d recommend checking two things:
TLS and STARTTLS:
Port 587: STARTTLS TRUE and TLS FALSE
Port 465: TLS TRUE and STARTTLS FALSE
Password:
The Google password must be entered without spaces to avoid errors.
If you continue to have problems even after making these changes, please share the program with me if possible so I can check it and help you.
williamFolle
Contributor
1
213
TLS and STARTTLS:
Password:
KrzysztofSoczewka
KrzysztofSoczewka
Contributor
Posted: ‎2026-07-20 03:12 AM
In response to williamFolle
Thank you for your help. The issue was caused by spaces in the password. After removing them, it works correctly.
