Ratiometric pressure sensor power
HVAC and Pumping Forum
  • Industrial Automation
  • HVAC and Pumping Forum
  • Re: Ratiometric pressure sensor power
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
otrotabi
otrotabi
Contributor
Posted: ‎2023-03-03 05:25 AM
2876
I got a couple of ratiometric pressure sensors which are taking far more current than expected. This means DC 5V is dropping to about 3.6 V (TM172PDG28R)
Besides ditching the sensors and getting new ones´is it possible to use an external power source ?
  • HVAC
  • ecostruxure
  • hvac
  • TM172
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2023-03-03 07:08 AM
Maximum current from 5Vout is 50mA.
Being ratiometric, I think you should use the 5V provided by M172.
Input impedance is higher than 20kohm, you should not have this kind of issues...
Replies 2
FedericoM
FedericoM Mentor
Mentor
otrotabi
otrotabi
Contributor
Posted: ‎2023-03-03 07:10 AM
Thanks. Yes, I would say so but wanted to make sure.
