Need help with using PIDAutoTuning FB
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Need help with using PIDAutoTuning FB
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
POPE3909
POPE3909
Explorer
Posted: ‎2026-05-21 08:42 PM
456
Hi Guys,
Trying to use PIDAutoTuning block for the first time but rKp and UiTi both output '0' after 3 oscillations.
uiMessageID shows '2' which I don't know where to look at what that number means?
Could you please advice on where I'm doing it wrong? (please see screen snip attached)
Abit of background if that matters, rPv is the differential pressure reading from a DP sensor and output is to control the pressurization fan.
Thank you.
  • HVAC
MargheritaM
MargheritaM Contributor
Contributor
Posted: ‎2026-05-24 11:36 PM
PIDAutoTuning returns rKp and uiTi equal to zero because usiMode=0 which means 'Manual mode' and your input manual values are all equal to zero.
You can refer to Help Online to have more deitails regarding FB input/output.
Help > Index > Library  > HVAC Library Guide > Regul and Control Function Blocks
Best regards,
Margherita
MargheritaM
Contributor
Best regards,
Margherita
MargheritaM
Contributor
Posted: ‎2026-05-25 03:39 AM
If you want, you can also try the PI and autotuning features of Application Addons library available at the following link: https://community.se.com/t5/HVAC-and-Pumping-Forum/Announcement-Application-Addons-Function-amp-Func...
Margherita
