Continue
  • My Subscriptions
  • Events
Maximum supply current on USB port CN17 in TM172
HVAC and Pumping Forum
  • Exact phrase โ†’ Use quotes " " (e.g., "error 404")
  • Wildcard โ†’ Use * for partial words (e.g., build*, *tion)
  • AND / OR โ†’ Combine keywords (e.g., login AND error, login OR signโ€‘in)
  • Keep it short โ†’ Use 2โ€“3 relevant words , not full sentences
  • Filters โ†’ Narrow results by section (Knowledge Base, Users, Products)
Showing results forย
Did you mean:ย
  • Industrial Automation
  • HVAC and Pumping Forum
  • Re: Maximum supply current on USB port CN17 in TM172
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
Caroko_Tri_Hatmojo
Caroko_Tri_Hatmojo
Explorer
Posted: โ€Ž2022-11-28 06:49 PM
2
1855
Does anyone here know, the max supply amperage from the TM172 USB port on channel CN17. I've looked into the manual, but nothing explains what the maximum supply current is for this port. Here I attached a photo of the port on the TM172 PLC (number 17).
  • TM172
  • USBPort
FedericoM
FedericoM Mentor
Mentor
Posted: โ€Ž2022-12-29 07:17 AM
1
1736
maximum current is 100mA.
Replies 2
FedericoM
FedericoM Mentor
Mentor
1
1737
Caroko_Tri_Hatmojo
Caroko_Tri_Hatmojo
Explorer
Posted: โ€Ž2023-09-27 09:57 AM
In response to FedericoM
Thanks for your answer. I'm sorry its very late to respond ๐Ÿ™‚
ย
Youโ€™ve reached the end of your document
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2026 Schneider Electric
