M172P* BACnet - attempting to edit device object name results in Write Access denied
HVAC and Pumping Forum
  • Industrial Automation
  • HVAC and Pumping Forum
  • Re: M172P* BACnet - attempting to edit device object name results in Write Access denied
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
obscuresc
obscuresc
Troubleshooter
Posted: ‎2024-02-01 07:25 PM
2247
I am setting up BACnet on TM172PDG18R. I have created a device object with the following properties
After downloading the project, and connecting via Yabe, the device appears correctly.
If I attempt to change the Object Name of the Device Object, I receive an 'ERROR_CODE_WRITE_ACCESS_DENIED'.
Document EIO0000004776 06/2022 'BACnet Application Notes' indicates that this property is writable.
If I go into the Configuration pane of ESME HVAC, I can edit the register associated, and the object name in Yabe will change.
Does mean that the object name is only available for edit via Modbus or via programming on the IEC-side?
Jack
  • HVAC
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2024-02-05 01:03 AM
string properties of BACnet objects can be modified from IEC code or via Modbus in case they are published also through this protocol, they can't be modified from BACnet BMS.
Replies 4
FedericoM
FedericoM Mentor
Mentor
obscuresc
obscuresc
Troubleshooter
Posted: ‎2024-02-06 02:43 PM
Thanks @FedericoM
Is that a limitation of BACnet or the M172?
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2024-02-07 11:31 PM
2195
BACnet requires UTF-8 chars while M172 and IEC code supports ASCII from Programming, so the only way to be compliant with BTL is to have read only strings from BACnet side
obscuresc
obscuresc
Troubleshooter
Posted: ‎2024-02-08 01:55 PM
In response to FedericoM
Thanks @FedericoM
