Posted: 2025-11-02 04:05 AM
Posted: 2025-11-05 05:06 AM . Last Modified: 2025-11-05 05:54 AM
Posted: 2025-11-02 11:06 PM
consider that all registers of TM172 are holding registers, you can use commands 3 for reading and 6,16 for writing. Registers are base 1, you can easily test using Modscan entering the same addresses.
Keep also in mind that TM172 answer with an exception if you try to read a not existing register with a multiple read (you might need to decrease the maximum number of registers to be read in one shot on Delta side).
Posted: 2025-11-03 05:28 AM
And you get a big problem if you have not only continous register adresses.You have to check this point in ESME HVAC.
Posted: 2025-11-03 06:22 AM
The variable ordering in the Delta panel's CSV file is different from that in the Schneider PLC's CSV file. It might be easier for you to first try a test by creating the variables individually in the Delta HMI, and then attempt to retrieve the data using the CSV file.
STEP-1
STEP-2
STEP-3
Posted: 2025-11-09 05:26 AM
Thank you for you help full record... It was usefull.
