M172 losing PLC file
HVAC and Pumping Forum
  • Industrial Automation
  • HVAC and Pumping Forum
  • M172 losing PLC file
FedericoM
Captain FedericoM Captain
93
Bastian_Schmitz
Admiral Bastian_Schmitz Admiral
56
M_Cervati
M_Cervati Support
15
product field
EcoStruxure™ Machine Expert - HVAC
POPE3909
Ensign POPE3909
Posted: ‎2024-02-14 10:54 PM
1116
Hi Guys,
I have a M172 on site that has been running fine for at least 2-3 years without any issue. One day the controller stops doing its function and when I logged into it via Machine Expert HVAC, it says NO CODE at the bottom right corner.
So, I tried doing a full download and download completed successfully but once I restart it, it goes back to NO CODE.
Then, I tried downloading only PLC code. After PLC only code download, I can do live-debug. But once I do a restart 'reboot target', it goes back to NO CODE.
What could be the problem? When I read the EEPROM registers after the restart, the values are still there so I assume the flash memory is still fine but somehow the PLC file keeps getting lost.
What could the likely cause for that? Thanks in advance.
  • HVAC
Replies 2
Bastian_Schmitz
Admiral
Posted: ‎2024-02-20 11:52 AM
1082
Sounds like the flash memory of the controller is broken. I never seen this on TM172 but I see this behavior on TM171P in combination with data logging. Could you open the file system of the controller via Commissioning?
best regards
POPE3909
Ensign POPE3909
Posted: ‎2024-02-20 10:43 PM
In response to Bastian_Schmitz
Hi Bastian,
Thanks for your reply. When I open the file system via Commissioning 'Open file brower', the PLC and HMI files seems to be still there. (see attached screenshot.) while ESME HVAC showing 'NO CODE'.
