M172 PT1000 Analog Resistive Input
HVAC and Pumping Forum
  • Industrial Automation
  • HVAC and Pumping Forum
  • M172 PT1000 Analog Resistive Input
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
Hanif777
Hanif777
Explorer
Posted: ‎2023-04-06 11:03 PM
4389
Hello, I'm trying to integrate a  2-wire PT1000 into my M172
I've set the corresponding parameter ( in this case the Cfg_AI8 ) to 6=PT1000, and although I got some reading, I'm not quite sure what is it exactly (it hovers around 400 INT dropped to 160 when I put some ice)
So my question is:
1. Does the FullScaleMin_AI8 & FullScaleMax_AI8 parameters need to be adjusted too? I kept it default at 0...1000
2. Does the value gained from the local IO variable (AIL8) is still in Ohm or has it been converted to temperature?
3. If it's still in Ohm any quick conversion library / FB I can use instead of manual conversion?
That's all, thanks!!
  • HVAC
Bastian_Schmitz
Champion
Posted: ‎2023-04-07 01:33 AM
4381
The sensor give a feedback with with one decimal place 100=10,0‘c
fullscale min and max work only for current and voltage inputs. The gain is only used by n the factory to calibrate the inputs.
please check if the Parameter for the unit is correct C/F .
and check if in your configuration the pair of AI is set to PT1000
best regards
Replies 4
Bastian_Schmitz
Champion
4382
best regards
Hanif777
Hanif777
Explorer
Posted: ‎2023-04-07 10:29 AM . Last Modified: ‎2023-04-07 10:29 AM
In response to Bastian_Schmitz
Alright I guess so, thanks!
That means I got 40.4 C ambient temp & 16.1 C when put with ice
Hmmm guess I need to recalibrate the sensor, or simply just not buy a cheap one 😕
kasmic_mike
kasmic_mike
Contributor
Posted: ‎2023-04-28 01:55 AM
4284
hi there,
if you are using ESME for programming your plc i recommend you use the LIN_TRAFO function block to scale your sensor output. check out that link for detail
https://product-help.schneider-electric.com/Machine%20Expert/V2.0/zh/Util/Util/modules/LIN_TRAFO.htm...
KASMIC
otrotabi
otrotabi
Contributor
Posted: ‎2023-04-28 04:03 AM
In response to kasmic_mike
Hi Mike,
What do you mean ? Are Codesys FB´s available as a library for ESME ? I asked some time ago and there´s no "official" implementation so far , at least the moment I asked there was not.
