Leds TM172DGRP monochrome panel
HVAC and Pumping Forum
  • Exact phrase โ†’ Use quotes " " (e.g., "error 404")
  • Wildcard โ†’ Use * for partial words (e.g., build*, *tion)
  • AND / OR โ†’ Combine keywords (e.g., login AND error, login OR signโ€‘in)
  • Keep it short โ†’ Use 2โ€“3 relevant words , not full sentences
  • Filters โ†’ Narrow results by section (Knowledge Base, Users, Products)
Showing results forย
Did you mean:ย
  • Industrial Automation
  • HVAC and Pumping Forum
  • Re: Leds TM172DGRP monochrome panel
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
inspro
inspro
Explorer
Posted: โ€Ž2024-11-16 01:31 PM
1102
Hello
I have a TM172PDG28RI controller and a TM172DGRP monochrome panel
The TM172DGRP panel has three leds
Question:
How to make the leds on the TM172DGRP panel reflect those on the TM172PDG28RI controller (red/yellow/green)
I assumed that this was done automatically after setting up communication, but the LEDs did not light up.
I have the same configuration for the display on the controller and remote panel
  • HVAC
Bastian_Schmitz
Champion
Posted: โ€Ž2024-11-17 11:02 PM
You need to control the LED via Display part. You could find a sample for this in the integrated TVDAs Chiller Large/ AHU Large.
You need to create a Global Procedure to activate the LEDs.
And you need to read the status for the LED mostly via Video_GetParam function.
You could find here the TVDAs
Replies 3
Bastian_Schmitz
Champion
inspro
inspro
Explorer
Posted: โ€Ž2024-11-19 08:45 AM
Thank you Bastian for your help
I can control LEDs on the operator screen turn off and on the LEDs by manually entering the values โ€‹โ€‹in the variable:usiLEDsCPU: USINT Array (0...2)
I have a problem with the GetParam function. I entered in GlobalOnTimer:
uiRET := Video_GetParam( 0, sysLocalLeds, 0, usiLEDsCPU, tyUSInt);
sysLocalLeds:= usiLEDsCPU;
There is no error during download, but the LEDs on the panel do not work.
Can you write what I did wrong?
I am a beginner in programming Medicon controllers. I work mainly with Siemens controllers and the TIA portal program.What is very simple in Scheider Electric is difficult and vice versa ๐Ÿ™‚
Bastian_Schmitz
Champion
Posted: โ€Ž2024-11-25 06:51 AM
You need to specify the modbus Register of sysLocalLeds in the function Video_getParam. In the TVDA all variabels which are written in UPPERCASE are constanst for the register adress. In you case you need to enter as adress 8640 LED1 8641 LED2 8642 LED.
ย
Youโ€™ve reached the end of your document
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2026 Schneider Electric
