HMI Transfer Mode
HVAC and Pumping Forum
  • Industrial Automation
  • HVAC and Pumping Forum
  • Re: HMI Transfer Mode
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
RodDom18
RodDom18
Explorer
Posted: ‎2024-09-12 02:03 AM
2570
HMI Transfer Mode
Hi there!
I'm using an HMI HMIST6500 and I've downloaded a program from Ecostruxure Operator Terminal Expert but I forgot to put a button that can make me go back to transfer mode, so now everytime I start the HMI it will go straight to the program. How can I go back to transfer mode? What can I do? Can you help me out?
  • Connectivity
Bastian_Schmitz
Champion
Posted: ‎2024-09-12 04:07 AM
You could open the hardware menue via a special click combination LINK
If this feature is disabled you could use the recovery menu which you could open during start up with a special click combination. LINK
Replies 2
Bastian_Schmitz
Champion
RodDom18
RodDom18
Explorer
Posted: ‎2024-09-27 07:49 AM
The touchscreen isn't very stable. Sometimes it works, sometimes it doesn't. There was one time I had to be around 10 minutes doing the click combination procedure until it worked. It was very frustrating. But indeed was the solution. Thank you!
