Example usage of HTTPLib_POST (HTTPLib)
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Example usage of HTTPLib_POST (HTTPLib)
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
KrzysztofSoczewka
KrzysztofSoczewka
Contributor
Posted: ‎2026-07-12 11:46 PM
367
I'm using HTTPLib_POST (HTTPLib library, embedded target) to send a JSON body to an external HTTP API.
Looking at the inputs, reqHeaders (STRING[2047]) accepts headers directly as a string, but there's no direct string input for the body – only srcFilename ("Source filename to be posted as body"). So the only way seems to be:
  1. Write the JSON to a file first (e.g. HTTPLib_SaveBinaryFile)
  2. Pass that filename via srcFilename in HTTPLib_POST
  3. Read responseStatusCode / responseBody once done is TRUE
This works for me, but I'd like to confirm:
  • Is file-based body really the only intended method, or is there a variant/way to pass the body as a string directly?
  • Is there an official example project showing HTTPLib_POST with a JSON body?
Any pointers would be appreciated. Thanks!
  • HVAC
williamFolle
williamFolle Contributor
Contributor
Posted: ‎2026-07-17 03:08 AM
In response to KrzysztofSoczewka
Hello, yes, I can confirm that you only need to specify the name of the document you created.
In your case,
srcFilename := 'loki_body.json';
should be enough to make everything work.
Replies 4
MargheritaM
MargheritaM Contributor
Contributor
Posted: ‎2026-07-14 02:53 AM
341
unfortunatelly there isn't a way to pass the body with a STRING, you have to use a file which results more flexible in terms of dimensions.
Regarding an example project, we are working on an example showing how to use HTTP GET, POST, DELETE and PATCH. It will be released in the following weeks.
Margherita
KrzysztofSoczewka
KrzysztofSoczewka
Contributor
Posted: ‎2026-07-16 04:49 AM
In response to MargheritaM
324
It's my code
count := count + 1;
IF count = 100 THEN
Start := TRUE;
count := 0;
END_IF;
epochSec := GetEpochTime_s();
refresh_post(enable := TRUE, period := period1);
trigEdge(clk := refresh_post.out);
IF trigEdge.q AND seq = 0 THEN
deleteResult := HTTPLib_DeleteFile(filename := bodyFile);
url1 := 'https://logs-prod-043.grafana.net/loki/api/v1/push';
reqHeaders1 := 'Authorization: Basic MTY2NzI2OTpnbxxxxxxxx';
reqHeaders1 := CONCAT(reqHeaders1, '$R$N');
reqHeaders1 := CONCAT(reqHeaders1, 'Content-Type: application/json');
jsonBody := '{"streams":[{"stream":{"job":"plc","device":"PLC1"},"values":[["';
epochStr := TO_STRING(epochSec);
epochStr := CONCAT(epochStr, '000000000');
jsonBody := CONCAT(jsonBody, epochStr);
jsonBody := CONCAT(jsonBody, '","temperatura=');
valStr := TO_STRING(v08740);
jsonBody := CONCAT(jsonBody, valStr);
jsonBody := CONCAT(jsonBody, '"]]}]}');
saveResult := HTTPLib_SaveBinaryFile(
filename := bodyFile,
inBuff := ADR(jsonBody),
buffSize := LEN(jsonBody)
IF saveResult = 0 THEN
enablePost := TRUE;
seq := 1;
END_IF;
END_IF;
post1(
enable := enablePost,
url := url1,
srcFilename := '/SD/loki_body.json',
reqHeaders := reqHeaders1,
tls := TRUE,
allowIfServerNotVerified := FALSE
postTimeout(in := (seq = 1), pt := 5000);
IF post1.done OR postTimeout.q THEN
IF post1.done THEN
statusCode := post1.responseStatusCode;
responseBody := post1.responseBody;
END_IF;
enablePost := FALSE;
seq := 0;
postTimeout(in := FALSE); // reset timera
END_IF;
Start := FALSE;
I think the problem may be caused by an incorrect file path: srcFilename := '/SD/loki_body.json';. What path should be used?
williamFolle
Contributor
In your case,
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2026-07-17 06:58 AM
The http functions working on files use a private internal filesystem, filename is enough
