[ESME-HVAC] Declared Variable(STATUS,LOCAL) on Configuration Tab doesn't show up in Configuration_variable tree on Programming Tab.
HVAC and Pumping Forum
  • Industrial Automation
  • HVAC and Pumping Forum
  • [ESME-HVAC] Declared Variable(STATUS,LOCAL) on Configuration Tab doesn't show up in Configuration_variable tree on Programmin...
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
product field
EcoStruxure™ Machine Expert - HVAC
StevenCho
StevenCho
Contributor
Posted: ‎2025-07-22 03:42 PM
1136
Hi there,
I’m currently using the TM172PDG42RI with ESME-HVAC software and encountered an issue:
Variables declared in the Configuration tab —  STATUS and LOCAL (I/O) — are not appearing in the Configuration_variable tree in the Programming tab.
Here’s what I did:
  1. Declared STATUS and LOCAL (I/O) variables in the Configuration tab.
  2. Built the project, but some of the declared variables didn’t show up in the Programming tab.
  3. Tried recompiling and refreshing the target, but the issue persists.
Thank you in advance.
Regards, Steven
  • HVAC
  • ESME-HVAC
  • TM172PDG42RI
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2025-07-23 07:39 AM
Try to alphabetically order EEprom and Status and check if you have duplicated variables name.
There is a known issue in the Configuration Perspective, this part is case sensitive, so duplicated names like ABC and abc aren't detected causing a visibility issue in the Programming side
Replies 3
Bastian_Schmitz
Champion
Posted: ‎2025-07-22 11:51 PM
1119
Did you made a build all via the upper menue
This is important to updat the programming part after enhancing the configuration tab.
Try to compie the configuration tab and check on this sid if there is some error.
A problem for an missing update could be overlapping memory (16Bit/32Bit variabel) or identical names, or special characters in names.
You will see this mostly in the output in window after compilinng in configuration.
FedericoM
FedericoM Mentor
Mentor
StevenCho
StevenCho
Contributor
Posted: ‎2025-07-23 11:04 PM
In response to Bastian_Schmitz
Thank you for the solution.
My mistake..
I expected to see the error like "duplicated variable..", So I couldn't notice it.
Thank you!
