Converting the Variables in variables using Eco Structure Machine Expert
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Converting the Variables in variables using Eco Structure Machine Expert
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
MohammedAvensis
MohammedAvensis
Explorer
Posted: ‎2025-11-03 07:35 AM
739
I am Communicating with a slave device and I able to read the variables value from 2 WORD Locations and after Combining the WORDs into a single DWORD and unlike Eco Structure Machine Expert I am not able to convert the DWORD into a Real Value using Unions or pointers in Eco Structure Machine Expert HVAC ..
  • HVAC
  • Modicon M2xx
M_Cervati
Troubleshooter
Posted: ‎2025-11-05 03:00 AM
Dear Mohammed,
there is a trick for TM172P to read 32 bits in  modbus.
Please see the DEMO in attachment for TM172P and for TM173O.
Best regards
Marco Cervati
HowToManageRealNumberESME.pptx
HowToManage32bitWithTM173.zip
testRealVarModbusESME.zip
M_Cervati
Troubleshooter
Dear Mohammed,
Best regards
Marco Cervati
Bastian_Schmitz
Champion
Posted: ‎2025-11-17 10:30 PM
Additional to Marcos tips, since ESME HVAC 1.7 the function to creat a REAL from two WORD is included in the standard librarys
The syntax is a little bit different in ESME HVAC comparing to Codesys based ESME
@ is used instead of ^
