84606members
353882posts
Com'X200 Power Options
Gateways and Energy Servers
Get expert answers to your questions regarding Schneider Electric Gateways & Energy Servers, from product selection to implementation and troubleshooting. Collaborate with a global community of experts and peers, get support and share your experiences by subscribing to the Schneider Electric Community Gateways and Energy Servers forum today.
LaurentCoene
Captain Captain
Captain
As you probably already know, the Com'X200 comes with 3 ways to get powered:
  1. 100 -> 230VAC (+/- 15%)
  2. 24VDC (+/- 10%)
  3. PoE
What you might less be aware of is that you can use multiple ways to power your box to provide redundancy.
For example you can use Option 1 (VAC) and have a small 24V UPS on Option 2. Which means that if Option 1 goes down, it will automatically switch to Option 2.
Order of redundancy is as described: first the box will use the VAC, if not available, it goes to VDC. Finally if not available it goes to PoE.
Finally not that only one of the ethernet port is PoE enabled and there's a small marking on the box to remind you which one (the left one!).
1908
Tags (3)
12 Replies 12
Digital_Hastak
Lieutenant JG Lieutenant JG
Re: Com'X200 Power Options
Would there be any issues if the customer were to power up ComX200 with 240VAC and 24VDC at the same time, where 24VDC is a back up supply.
or POE with 240VAC/24VDC as a back up supply simulateously.
Would there be any priority issue?
LaurentCoene
Captain Captain
Captain
No issue at all! That's the all point.
The priority goes as followed: VAC, then VDC, then PoE.
So again, typically I would plug the VAC and then have a small DIN-Railed 24VDC UPS for backup!
LaurentCoene
Captain Captain
Captain
Beware that on the VAC power supply side, even though some of the old documentation mentions 277VAC, the first release will only go up to 230VAC (+/- 15%). (Thanks !)
sesa252887_brid
Schneider Alumni (Retired)
Do we have SE PoE supply offer?
thanks
LaurentCoene
Captain Captain
Captain
Not aware of any, but doesn't mean we don't have one...
sesa209813
Hello ,
Is the PoE Injector Kit, TCSEAV0100, what you are looking for?
Here is a link to the installation guide (63230-319-206): http://download.schneider-electric.com/files?L=en&p=&p_docId=&p_docId=&p_Reference=63230-319-206&p_E... guide&p_File_Id=27448644&p_File_Name=63230-319-206.pdf
sesa209813
I'm not sure why that link broke... Here it is.
JamesAZZO
Sisko | EcoXpert Master Sisko | EcoXpert Master
This is soooo good! As per this old thread we really really needed this (especially now that it has the latest Ethernet Gateway functionality!) and this fixes a lot of problems we were having creating redundancy (unable with EGX)
Any chance this could also be an ION Protocol Gateway in a future firmware? (basically - a straight serial port encapsulation with no protocol conversion) - - we are buying Lantronix now for this. Why not offer it as a setting for our new device here?
sesa41299
ION protocol is on the roadmap.  You will see it on the new gateway offers first. Later it will make its way on to the Energy Servers.
sesa57006_bridg
Crewman Crewman
Is the Com'X 200 (210/510) powered by POE able to power all the Outputs, wireless, and future expansion modules without limitations? Do we know the limitations if any? Any increase thermal issues?
aaadria
Hi Jonathan,
there's at least one limitation specified (on the technical Leaflet that comes with the datalogger) which is that the GPRS dongle can't work with PoE.
On top of that, the PoE standard (802.3af) on COM'X200 grant at most around 13W, while the COMX max consumption is 26W. So it's possible that there are more limitations.
Hope it helps
sesa57006_bridg
Crewman Crewman
Thanks for the quick answer. Is this a short term situation (with GPRS) that will be fixed with a FW or HW (210 / 510) update?
