82167members
349757posts
Is a Replacement CO2 Sensor Available For a Living Space Sensor
Field Devices Forum
Collaborate with a community of professionals and find answers and discuss anything related to the Field Devices (Sensors, Thermostats, Valves & Actuators and more)
arlena
784
The Co2 sensor is removable from the SXWSBTXCXSXX , but I can't find the part number to order a replacement.  Are they available?
CraigEl
Re: Is a Replacement CO2 Sensor Available For a Living Space Sensor
I don't believe that this is intended as a field replaceable item
Troy_Wecker
Ensign Ensign
572
The CO2 Sensor is Non Dispersion InfraRed (NDIR).  It does not contain a chemical element.  That provides for a typical longer life and reliability,  is not intended for field replacement.  The product electronics continually monitors the sensor and provides continued accuracy.
6 Replies 6
CraigEl
Troy_Wecker
Ensign Ensign
573
arlena
475
We are seeing maybe 1or 2% failure (as in reading 0) within 1 year.  If they were not meant to be replaceable, SE should save the money and solder them to the board without using a socket!
CraigEl
I dare say that they also aren't designed to have that sort of failure rate either... I suggest that you contact your local support channel to have them replaced under warranty. You might also request a failure analysis, known in SE as a TEX request.
Troy_Wecker
Ensign Ensign
458
The CO2 sensor on the SXWSBTXCXSXX isn't socketed.  It's not field replaceable.
arlena
The one in front of me is 🙂
See attachment.   So the only reason it is not field replaceable is because SE chooses not to make it available for replacement.
