Field Devices Forum
Schneider Electric support forum about all Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
Posted: 2021-10-05 01:57 AM
Hello team,
Could you please clarify if the VB-8303 style 3-way valve body have the common “AB” port come out the side port?
Posted: 2021-10-05 02:09 AM
On the VB-8303 the bottom port is always on the bottom, it is the common port.
Do you have this valve already? There are other valve types where the common port AB is on the side.
What region are you in?
Posted: 2021-10-06 05:10 AM
Thanks David,
Yes, I have already this VB-8303 valve body.
I am located in France.
Best regards
AntonB
Posted: 2021-10-06 05:48 AM
Hi @Anton_Balanescu ,
As you already have the valve and probably the actuator too, I'm not sure if this is of help now:
I've attached a link to the EMEA Valve and Actuator catalogue, it has globe valves with the common AB port on the side.
Posted: 2021-10-06 05:59 AM
The VB-9313 series has the common port on the side. As previously commented, the VB-8303 must be piped per the diagram for it to function properly.
