Editing properties
Editing properties
Send InviteCancel
Right-click any room, floor equipment (including racks), or rack-mountable equipment in a Navigation pane, or Layout pane and select Properties to access and edit the properties.
To edit properties for a selected component, right-click it in the floor/rack Layout or Navigation pane and select Properties and perform the edits in the Properties dialog box.
To edit properties for a component in the genome library, i.e. all pieces of this equipment added to the floor or rack layout subsequently, open Genomes, select a component in the Floor Equipment or Rack-Mountable Equipment pane and perform the edits in the Properties section.
To add custom properties, perform one of the above steps, and in the Properties (Custom) section, select Add, then in the Add Custom Properties dialog box, type the name and value for the new property.
To add power connection properties, perform one of the above steps, and in the New Power Connection dialog box, accessed in the Power Dependency (CRAC) or Power Distribution (PDU or remote distribution panel (RDP)) section, select New to add a new power connection or Edit to edit an existing connection.
