  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      • Protection & Control
      APC UPS, Critical Power, Cooling and Racks
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • Alliance System Integrators Forum
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • EcoStruxure Automation Expert / IEC 61499 Forum
      • Fabrika ve Makina Otomasyonu Çözümleri
      • Harmony Control Customization Forum
      • Industrial Edge Computing Forum
      • Korea Industrial Automation Forum
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Eldistribution & Fastighetsautomation
      • Elektrik Tasarım Dağıtım ve Uygulama Çözümleri
      • Paneelbouw & Energie Distributie
      • Power Distribution and Digital
      • Solutions for Motor Management
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      • Power Monitoring and Energy Automation NAM
      Power Distribution Software
      • EcoStruxure Power Design Forum
      • LayoutFAST User Group Forum
      Energy & Sustainability Services
      • Green Building Scoring and Certification Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      • Solutions for your Business Forum
      Support
    • Remote Operations Devices Knowledge Base
    • Geo SCADA Knowledge Base
    • Industrial Automation How-to videos
    • Digital E-books
    • Success Stories Corner
    • EcoStruxure IT Help Center
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      • EcoStruxure Building Advisor Ideas
      Remote Operations
      • EcoStruxure Geo SCADA Expert Ideas
      • Remote Operations Devices Ideas
      • Modicon Ideas & new features
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • Active Energy Management Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
Important Announcement: Community Back to Full Functionality
Dear Members, we are thrilled to announce that our Community is back to full functionality and that posts publication is now enabled again! We appreciate your patience during the last weeks. Learn more about our Community Guidelines. Thank you, Schneider Electric Community Team.
Powertag Power readings are not correctly shown in DCE
  • Communities
  • Powertag Power readings are not correctly shown in DCE
  • Subscribe to RSS Feed
Captain Jef Captain
79
Commander APC_Steve Commander
55
Commander gsterling Commander
50
Lt. Commander Cory_McDonald Lt. Commander
15
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 08:58 PM
661
This question was originally posted on DCIM Support by ozgur on 2019-07-25
Hello community,
We are having trouble with reading power values via powertags in DCE . We added 4 acti 9 smartlink devices in DCE with 20 powertags connected wirelessly to each of them.
When access directly to web server of acti 9 smartlinks we can read the power values as shown at the screenshot below ;
But in DCE ; link status is online , data looks corrupted .
Devices are being added in modbus tcp device add section.For device type i can only choose " Acti9 Smartlink Modbus " to make it online.
I have downloaded and imported the two DDF files from DDF library portal which are related with Acti9 devices. Slave address of smartlinks looks impossible to change they are all 255 . İ couldnt at least. When i delete the other discovered smartlinks and tried out just one with same 255 slave address also couldnt have success in power readings. I think slave address section is not the subject in this situation.
We use powertag 1560 and 1570 models. Smartlink devices are upgraded to latest 2.2.7 firmware. Data Center Expert is not yet upgraded to R 7.6  .Its a phsiycal appliance running with delivery Release 7.4.1.
I hope i could explain the problem. Any advice that you give me would be highly appreciated.
Thanks in advance.
Best regards.
Ozgur.
(CID:147198240)
  • DDF
663
This answer was originally posted on DCIM Support by Jake Hiltz on 2019-07-25
Hi Ozgur,
Because you are using Powertag sensors, I think you have an Acti9 Smartlink SI B or D.  In this case, you will want to use the "schneider_acti9_smartlinksid.xml" DDF which you can download from the DDF download page (it looks like you are using the DDF with the file named "schneider_acti9_smartlink.xml" - the names are so similar, this can be confusing).
In addition to using that DDF, you will want to enter the slave address of the Powertag sensor, not the Acti9 itself.  The Acti9 will assign the sensors the Modbus slave address automatically, so you will probably have to look in the Acti9 configuration to know which addresses go with which sensors.
From page 79 of the Smartlink SI D manual:  "Acti9 Smartlink SI D allocates dynamically, a slave number 150 through 169 for each of the 20 wireless communication devices (up to 20 wireless communication devices) that could be connected to the Acti9 Smartlink SI D."
Let us know if this resolves your issue.
Jake
(CID:147198453)
664
Hi Ozgur,
Jake
(CID:147198453)
This comment was originally posted on DCIM Support by ozgur on 2019-07-25
Hi Jake,
Thank you very much for your help. Your information about adding powertags seperately with the same ip address of smartlink SI D,  but with unique slave address solved my issue. I tought that just adding smartlink will be enough for viewing powertags running behind it and i now see it was so wrong. Finally i will submit the project. It was urgent.
Thanks a lot again.
Best regards.
Ozgur.
(CID:147198584)
Posted: ‎2020-07-05 08:59 PM
You can subscribe to this forum after you log in or create your free account.
Terms & Conditions Privacy Notice Change your Cookie Settings © 2023 Schneider Electric, Inc
