Posted: 2020-07-03 02:34 PM . Last Modified: 2024-04-08 01:16 AM
Some of the NMC2's that I updated to firmware version 6.4.6 still list as being at 6.4.0 in InfraStruxure Central 6.2
(CID:116361240)
Hi Richard,
This is a known issue and can be easily resolved however it is not tested with the older versions of StruxureWare. Please check out k-base FA303882. It has not been tested with 6.x StruxureWare Central so I would suggest first contacting tech support for an upgrade. Should you wish to try this on the old version (and I can not recommend that), I would suggest you create a backup first as I'm unsure how this may effect the older system.
(CID:116361247)
Hi Richard,
(CID:116361247)
Posted: 2020-07-03 02:35 PM . Last Modified: 2024-04-08 01:16 AM
YOU HAVE TO UPDATE YOUR DCE VERSION TO A LATEST APPROXIMATELY 7.2.7 . OR ABOVE . ISSUE LL BE RESOLVE .
(CID:116362649)
Posted: 2020-07-03 02:35 PM . Last Modified: 2023-10-22 03:08 AM
