84821members
354275posts
How to fetch data from a third Party API to the DCE
Warne
1499
Is there a way to integrate a third party API with the DCE? There are only few status to be monitored through this API.
Thank you.
APC_Steve
Commander Commander
4
1473
Re: How to fetch data from a third Party API to the DCE
Hi @Warne ,
The API available through DCE is for monitoring DCE and it's devices. Your question however seems to be more related to DCE using an API to monitor a 3rd party device. Sorry but there is no option for this. DCE can monitor SNMP and modbus 3rd party devices. It does use an API to monitor NetBotz devices however that is a built-in functionality and not outwardly exposed for use with other systems.
5 Replies 5
APC_Steve
Commander Commander
4
1474
Hi @Warne ,
gunturhakim
2
1455
Hi Steve,
that true, DCE have own API
bandungbest regards
APC_Steve
Commander Commander
1
1447
hi @gunturhakim ,
I'm not sure if that's a question or statement but yes, that's true. If you need information, it can be found here:
https://dcimsupport.ecostruxureit.com/hc/en-us/sections/360006467394-DCE-web-services-API
Gabriella
I want to make a website, which will be a sort-of search engine. A user enters a search term in a text box, and that data will be sent to several third party API's as query. Because the API's of course don't return completely similar responses, the data has to be parsed.
Kroger Schedule
Warne
Thanks Steve.
