84589members
353855posts
How to IP/Configure and add device Netbotz 455
DCIM_Support
Picard
Picard
381
This question was originally posted on DCIM Support by Zeke Moreno on 2018-07-17
(CID:132665962)
5 Replies 5
DCIM_Support
Picard
Picard
Re: How to IP/Configure and add device Netbotz 455
This answer was originally posted on DCIM Support by John Benedict Tayao on 2018-07-18
Hi Zeke,
You can reference the link below on how to configure an IP on a Netbotz appliance.
http://www.apc.com/ph/en/faqs/FA308010/
Can you confirm what devices you are planning to add/configure on the Netbotz?
John
(CID:132666027)
DCIM_Support
Picard
Picard
381
This answer was originally posted on DCIM Support by Zeke Moreno on 2018-07-24
John,
Thank you very much for your answer and reference link. It was helpful info. To answer your question. We are using Flood, Temp, and Humidity sensors on the Netbotz 455. Sorry for the delay response.
Zeke
(CID:132668460)
DCIM_Support
Picard
Picard
This comment was originally posted on DCIM Support by John Benedict Tayao on 2018-07-25
Hi Zeke,
If you are referring the Flood sensor as the Leak Rope sensor, it is not compatible with the Netbotz 455 (Room monitor).  Below link is the compatibility matrix for Netbotz.
http://www.apc.com/salestools/JHIN-7PTK7P/JHIN-7PTK7P_R7_EN.pdf
Hope this helps.
Kind regards,
John
(CID:132668688)
DCIM_Support
Picard
Picard
This comment was originally posted on DCIM Support by Zeke Moreno on 2018-07-26
Thank you, for the heads up! I was not aware of that.
(CID:132669555)
DCIM_Support
Picard
Picard
🔒 Closed
