Heat loss UPS and redundancy
  • EcoStruxure IT forum
  • 🔒 Closed
  • Subscribe to RSS Feed
Cory_McDonald
Admiral Cory_McDonald Admiral
124
Jef
Admiral Jef Admiral
108
gsterling
Captain gsterling Captain
71
APC_Steve
Captain APC_Steve Captain
62
Back to EcoStruxure IT forum
DCIM_Support
Picard DCIM_Support
Picard
Posted: ‎2020-07-04 02:36 PM . Last Modified: ‎2024-04-05 02:35 AM
753
Hi team,
How does DCO calculate the estimated heat loss of a UPS in cooling tab?
For examplo in this screenshot we have 1.0 kW in UPS-A and 0.9 kW in UPS-B.
And also, why one UPS has N+1 cooling redundancy and the other N+2?
(CID:128761916)
  • Data Center Operation
DCIM_Support
Picard DCIM_Support
Picard
Hi Javier,
I don't think there is a simple formula for expressing the Estimated Heat Loos (in 2D simulation), however based on the temperature difference between inlet and outlet temperature the Estimated Heat Loos is 'calculated'.
And for the cooling redundancy,
N+1, there is one redundant cooling unit for the rack/ups, eg. one cooler can fail anywhere in the data center and cooling will still be adequate.
N+2, there are two redundant cooling units for the rack/ups, eg. two coolers can fail anywhere in the data center and cooling will still be adequate.
For more info, please see the following page: Cooling Redundancy
Kind regards
(CID:128763004)
Replies 2
DCIM_Support
Picard DCIM_Support
Picard
Hi Javier,
Kind regards
(CID:128763004)
DCIM_Support
Picard DCIM_Support
Picard
Posted: ‎2020-07-04 02:36 PM . Last Modified: ‎2023-10-22 02:15 AM
This is a heading
