Posted: 2020-06-10 06:07 AM
Hi Team!
We have an issue when DCO desktop client crashes mostly when user add power equipment (rPDU or ATS) to the rack from the library.
Client stucks for a while then shows the message that it will be restarted.
There is such rows in application.log:
2020-06-10 10:13:55,386 ERROR [com.apc.sma.client.Application$EclipseToLog4jLogListener] (main) Problems occurred when invoking code from plug-in: "org.eclipse.jface". [org.eclipse.core.runtime]
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:4506)
at org.eclipse.swt.SWT.error(SWT.java:4421)
at org.eclipse.swt.SWT.error(SWT.java:4392)
at org.eclipse.swt.widgets.Widget.error(Widget.java:482)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:354)
at org.eclipse.swt.widgets.Control.setVisible(Control.java:3822)
at org.eclipse.jface.dialogs.DialogPage.setVisible(DialogPage.java:470)
at org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDialog.java:1260)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog.java:1223)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDialog.java:915)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:428)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4362)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1113)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4180)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3769)
at com.apc.config.workbench.threads.impl.AbstractThreadService.avoidBlockingDisplayThreadBeforeFutureIsDone(AbstractThreadService.java:103)
at com.apc.config.workbench.threads.impl.AbstractThreadService.waitForFuture(AbstractThreadService.java:77)
at com.apc.config.workbench.threads.impl.ModelModificationThreadServiceImpl.syncExec(ModelModificationThreadServiceImpl.java:223)
at com.apc.config.workbench.threads.impl.ModelModificationThreadServiceImpl.syncExec(ModelModificationThreadServiceImpl.java:204)
at com.apc.config.productcatalog.DefaultProductCatalogFactory.disposeCreatedItems(DefaultProductCatalogFactory.java:180)
at com.apc.excel.importer.impl.EquipmentImporterPlanImpl.cleanupAtCancel(EquipmentImporterPlanImpl.java:46)
at com.apc.excel.importer.ui.internal.ImportWizard.cleanupImporterPlan(ImportWizard.java:114)
at com.apc.excel.importer.ui.internal.ImportWizard.performCancel(ImportWizard.java:168)
at org.eclipse.jface.wizard.WizardDialog.okToClose(WizardDialog.java:954)
at org.eclipse.jface.wizard.WizardDialog.close(WizardDialog.java:485)
at org.eclipse.jface.window.Window.handleShellCloseEvent(Window.java:741)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:687)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:98)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1137)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1122)
at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations.java:308)
at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.java:1703)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4678)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:339)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1633)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2117)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5050)
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:2443)
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:496)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4774)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2549)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3767)
at org.eclipse.swt.widgets.Shell.close(Shell.java:538)
at org.eclipse.swt.widgets.Shell.traverseEscape(Shell.java:1996)
at org.eclipse.swt.widgets.Control.traverse(Control.java:4168)
at org.eclipse.swt.widgets.Control.translateTraversal(Control.java:4145)
at org.eclipse.swt.widgets.Display.translateTraversal(Display.java:4868)
at org.eclipse.swt.widgets.Display.filterMessage(Display.java:1284)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3765)
at org.eclipse.jface.wizard.WizardDialog.cancelPressed(WizardDialog.java:473)
at org.eclipse.jface.wizard.WizardDialog$1.widgetSelected(WizardDialog.java:323)
at com.apc.excel.importer.ui.internal.ImportWizard.createImporterPlan(ImportWizard.java:99)
at com.apc.excel.importer.ui.internal.ImportWizard.handlePageChanging(ImportWizard.java:136)
at org.eclipse.jface.wizard.WizardDialog$10.run(WizardDialog.java:1602)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.wizard.WizardDialog.firePageChanging(WizardDialog.java:1600)
at org.eclipse.jface.wizard.WizardDialog.doPageChanging(WizardDialog.java:929)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog.java:1218)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at com.apc.excel.importer.ui.ImportHandler.execute(ImportHandler.java:20)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:829)
at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:815)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:805)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.apc.sma.client.Application.start(Application.java:223)
at com.apc.isxo.client.bootstrap.BootstrapApplication.start(BootstrapApplication.java:136)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Customer uses DCO 8.3.2 on Windows 10 pro 64-bit. Are there any idea how to fix it?
Sometimes it crashes when user save changes:
2020-06-10 11:15:36,089 ERROR [com.apc.config.hibersync.client.internal.OperationModelClientRestHttpClientStrategy] (Model Thread 0) Unable to call /commitChanges/7caffaaf-4f72-4b48-8c73-09572957f5f6/64728:
com.apc.config.hibersync.client.internal.OperationModelClientApplicationException: Server sent an application Exception || threadjobid => {boep8iZnQxGbGPcvvjRtwQ}, caused by:
com.apc.itil.core.server.ServerException: An exception of type [java.lang.RuntimeException] happened on the server (the contained stacktrace is from the original exception on the server)
2020-06-10 11:15:36,120 WARN [com.apc.config.hibersync.client.internal.HiberSyncClientExistingModelSynchronizer] (Model Thread 0) Something went wrong, dumping modelChangesSnapshot to help debugging:
[com.apc.config.productcatalog.ui.internal.service.CustomCatalogClientMergeStrategy-snapshot:com.apc.config.productcatalog.impl.service.CustomCatalogSnapshot@647f8a33],
2020-06-10 11:15:56,596 ERROR [com.apc.sma.client.ExceptionHandlerImpl] (Model Thread 0) Unhandled exception: Server sent an application Exception || threadjobid => {boep8iZnQxGbGPcvvjRtwQ}
at com.apc.config.hibersync.client.internal.OperationModelClientRestHttpClientStrategy.throwDeserializedExceptionAsOperationModelClientApplicationException(OperationModelClientRestHttpClientStrategy.java:220)
at com.apc.config.hibersync.client.internal.OperationModelClientRestHttpClientStrategy.throwException(OperationModelClientRestHttpClientStrategy.java:180)
at com.apc.config.hibersync.client.internal.OperationModelClientRestHttpClientStrategy.commitChanges(OperationModelClientRestHttpClientStrategy.java:140)
at com.apc.config.hibersync.client.internal.OperationModelClientRestServiceImpl$1.invoke(OperationModelClientRestServiceImpl.java:117)
at com.apc.config.hibersync.client.internal.OperationModelClientRestServiceImpl$1.invoke(OperationModelClientRestServiceImpl.java:1)
at com.apc.config.hibersync.client.internal.OperationModelClientRestServiceImpl$ConsumeInterceptor.aroundInvoke(OperationModelClientRestServiceImpl.java:376)
at com.apc.config.hibersync.client.internal.OperationModelClientInvocationContext.proceed(OperationModelClientInvocationContext.java:30)
at com.apc.config.hibersync.client.internal.OperationModelClientRestServiceImpl.invoke(OperationModelClientRestServiceImpl.java:213)
at com.apc.config.hibersync.client.internal.OperationModelClientRestServiceImpl.consume(OperationModelClientRestServiceImpl.java:193)
at com.apc.config.hibersync.client.internal.OperationModelClientRestServiceImpl.commitChanges(OperationModelClientRestServiceImpl.java:114)
at com.apc.config.hibersync.client.internal.HiberSyncClientExistingModelSynchronizer.commitChangesToServer(HiberSyncClientExistingModelSynchronizer.java:252)
at com.apc.config.hibersync.client.internal.HiberSyncClientExistingModelSynchronizer.synchronize(HiberSyncClientExistingModelSynchronizer.java:116)
at com.apc.config.hibersync.client.HiberSyncClient.synchronizeOnExistingModel(HiberSyncClient.java:243)
at com.apc.config.hibersync.client.HiberSyncClient.synchronizeWithServer(HiberSyncClient.java:222)
at com.apc.dcoverview.OperationsClientPersistenceHelper.saveToDataBase(OperationsClientPersistenceHelper.java:141)
at com.apc.dcoverview.AbstractClientPersistenceHelper$Saver.save(AbstractClientPersistenceHelper.java:172)
at com.apc.dcoverview.AbstractClientPersistenceHelper$Saver.run(AbstractClientPersistenceHelper.java:149)
at com.apc.dcoverview.AbstractClientPersistenceHelper.commitToDataBase(AbstractClientPersistenceHelper.java:57)
at com.apc.dcoverview.internal.save.DefaultSaveService$SaveCallable.call(DefaultSaveService.java:150)
at com.apc.dcoverview.internal.save.DefaultSaveService$SaveCallable.call(DefaultSaveService.java:1)
at com.apc.config.workbench.threads.impl.wrappers.CallableWithProgressWrapper.call(CallableWithProgressWrapper.java:25)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
at com.apc.config.workbench.threads.impl.ModelModificationThread.run(ModelModificationThread.java:10)
Caused by: com.apc.itil.core.server.ServerException: An exception of type [java.lang.RuntimeException] happened on the server (the contained stacktrace is from the original exception on the server)
at com.apc.config.hibersync.server.OperationModelServerRestServiceImpl.buildUntypedServerExceptionResponseAndLogError(OperationModelServerRestServiceImpl.java:505)
at com.apc.config.hibersync.server.OperationModelServerRestServiceImpl.commitChanges(OperationModelServerRestServiceImpl.java:311)
at sun.reflect.GeneratedMethodAccessor2357.invoke(Unknown Source)
at org.jboss.as.ee.component.ManagedReferenceMethodInterceptor.processInvocation(ManagedReferenceMethodInterceptor.java:52)
at org.jboss.invocation.InterceptorContext.proceed(InterceptorContext.java:340)
at org.jboss.invocation.InterceptorContext$Invocation.proceed(InterceptorContext.java:437)
at org.jboss.as.weld.ejb.Jsr299BindingsInterceptor.delegateInterception(Jsr299BindingsInterceptor.java:70)
at org.jboss.as.weld.ejb.Jsr299BindingsInterceptor.doMethodInterception(Jsr299BindingsInterceptor.java:80)
at org.jboss.as.weld.ejb.Jsr299BindingsInterceptor.processInvocation(Jsr299BindingsInterceptor.java:93)
at org.jboss.as.ee.component.interceptors.UserInterceptorFactory$1.processInvocation(UserInterceptorFactory.java:63)
at com.apc.product.services.RequireOperationsOrColo.check(RequireOperationsOrColo.java:45)
at com.apc.product.services.RequireOperationsOrColo.verify(RequireOperationsOrColo.java:24)
at sun.reflect.GeneratedMethodAccessor2356.invoke(Unknown Source)
at org.jboss.as.ee.component.ManagedReferenceLifecycleMethodInterceptor.processInvocation(ManagedReferenceLifecycleMethodInterceptor.java:89)
at com.apc.config.hibersync.server.rest.HandleExceptionRestServiceInterceptor.check(HandleExceptionRestServiceInterceptor.java:31)
at com.apc.config.hibersync.server.rest.HandleExceptionRestServiceInterceptor.verify(HandleExceptionRestServiceInterceptor.java:26)
at sun.reflect.GeneratedMethodAccessor2355.invoke(Unknown Source)
at com.apc.config.hibersync.server.RequestInterceptor.intercept(RequestInterceptor.java:44)
at sun.reflect.GeneratedMethodAccessor1298.invoke(Unknown Source)
at org.jboss.as.ejb3.component.invocationmetrics.ExecutionTimeInterceptor.processInvocation(ExecutionTimeInterceptor.java:43)
at org.jboss.as.jpa.interceptor.SBInvocationInterceptor.processInvocation(SBInvocationInterceptor.java:47)
at org.jboss.weld.ejb.AbstractEJBRequestScopeActivationInterceptor.aroundInvoke(AbstractEJBRequestScopeActivationInterceptor.java:64)
at org.jboss.as.weld.ejb.EjbRequestScopeActivationInterceptor.processInvocation(EjbRequestScopeActivationInterceptor.java:83)
at org.jboss.as.ee.concurrent.ConcurrentContextInterceptor.processInvocation(ConcurrentContextInterceptor.java:45)
at org.jboss.invocation.InitialInterceptor.processInvocation(InitialInterceptor.java:21)
at org.jboss.invocation.ChainedInterceptor.processInvocation(ChainedInterceptor.java:61)
at org.jboss.as.ee.component.interceptors.ComponentDispatcherInterceptor.processInvocation(ComponentDispatcherInterceptor.java:52)
at org.jboss.as.ejb3.component.interceptors.NonPooledEJBComponentInstanceAssociatingInterceptor.processInvocation(NonPooledEJBComponentInstanceAssociatingInterceptor.java:59)
at org.jboss.as.ejb3.tx.CMTTxInterceptor.invokeInOurTx(CMTTxInterceptor.java:275)
at org.jboss.as.ejb3.tx.CMTTxInterceptor.required(CMTTxInterceptor.java:327)
at org.jboss.as.ejb3.tx.CMTTxInterceptor.processInvocation(CMTTxInterceptor.java:239)
at org.jboss.as.ejb3.component.interceptors.CurrentInvocationContextInterceptor.processInvocation(CurrentInvocationContextInterceptor.java:41)
at org.jboss.as.ejb3.component.invocationmetrics.WaitTimeInterceptor.processInvocation(WaitTimeInterceptor.java:47)
at org.jboss.as.ejb3.security.AuthorizationInterceptor.processInvocation(AuthorizationInterceptor.java:138)
at org.jboss.as.ejb3.security.SecurityContextInterceptor.processInvocation(SecurityContextInterceptor.java:100)
at org.jboss.as.ejb3.deployment.processors.StartupAwaitInterceptor.processInvocation(StartupAwaitInterceptor.java:22)
at org.jboss.as.ejb3.component.interceptors.ShutDownInterceptorFactory$1.processInvocation(ShutDownInterceptorFactory.java:64)
at org.jboss.as.ejb3.component.interceptors.LoggingInterceptor.processInvocation(LoggingInterceptor.java:67)
at org.jboss.as.ee.component.NamespaceContextInterceptor.processInvocation(NamespaceContextInterceptor.java:50)
at org.jboss.as.ejb3.component.interceptors.AdditionalSetupInterceptor.processInvocation(AdditionalSetupInterceptor.java:54)
at org.jboss.invocation.ContextClassLoaderInterceptor.processInvocation(ContextClassLoaderInterceptor.java:64)
at org.jboss.invocation.InterceptorContext.run(InterceptorContext.java:356)
at org.wildfly.security.manager.WildFlySecurityManager.doChecked(WildFlySecurityManager.java:636)
at org.jboss.invocation.AccessCheckingInterceptor.processInvocation(AccessCheckingInterceptor.java:61)
at org.jboss.invocation.PrivilegedWithCombinerInterceptor.processInvocation(PrivilegedWithCombinerInterceptor.java:80)
at org.jboss.as.ee.component.ViewService$View.invoke(ViewService.java:198)
at org.jboss.as.ee.component.ViewDescription$1.processInvocation(ViewDescription.java:185)
at org.jboss.as.ee.component.ProxyInvocationHandler.invoke(ProxyInvocationHandler.java:73)
at com.apc.config.hibersync.server.OperationModelServerRestService$$$view501.commitChanges(Unknown Source)
at sun.reflect.GeneratedMethodAccessor2354.invoke(Unknown Source)
at org.jboss.weld.util.reflection.Reflections.invokeAndUnwrap(Reflections.java:433)
at org.jboss.weld.bean.proxy.EnterpriseBeanProxyMethodHandler.invoke(EnterpriseBeanProxyMethodHandler.java:128)
at org.jboss.weld.bean.proxy.EnterpriseTargetBeanInstance.invoke(EnterpriseTargetBeanInstance.java:56)
at org.jboss.weld.bean.proxy.InjectionPointPropagatingEnterpriseTargetBeanInstance.invoke(InjectionPointPropagatingEnterpriseTargetBeanInstance.java:67)
at org.jboss.weld.bean.proxy.ProxyMethodHandler.invoke(ProxyMethodHandler.java:100)
at com.apc.config.hibersync.server.OperationModelServerRestService$1562214003$Proxy$_$$_Weld$EnterpriseProxy$.commitChanges(Unknown Source)
at sun.reflect.GeneratedMethodAccessor2353.invoke(Unknown Source)
at org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:139)
at org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTarget(ResourceMethodInvoker.java:295)
at org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:249)
at org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:236)
at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:402)
at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:209)
at org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.service(ServletContainerDispatcher.java:221)
at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:56)
at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:51)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:85)
at io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62)
at io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36)
at org.wildfly.extension.undertow.security.SecurityContextAssociationHandler.handleRequest(SecurityContextAssociationHandler.java:78)
at io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43)
at com.apc.server_extensions.undertow.AccessLoggingHttpHandler.handleRequest(AccessLoggingHttpHandler.java:68)
at io.undertow.server.handlers.PathHandler.handleRequest(PathHandler.java:94)
at com.apc.server_extensions.undertow.BlockRemoteManagementRequestHttpHandler.handleRequest(BlockRemoteManagementRequestHttpHandler.java:59)
at com.apc.server_extensions.undertow.ThreadJobContextHttpHandler.handleRequest(ThreadJobContextHttpHandler.java:43)
at io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:131)
at io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57)
at com.apc.server_extensions.undertow.HttpErrorCodeHandler.handleRequest(HttpErrorCodeHandler.java:45)
at com.apc.server_extensions.undertow.HttpHeadersHandler.handleRequest(HttpHeadersHandler.java:76)
at io.undertow.security.handlers.AuthenticationConstraintHandler.handleRequest(AuthenticationConstraintHandler.java:53)
at io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46)
at io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64)
at io.undertow.servlet.handlers.security.ServletSecurityConstraintHandler.handleRequest(ServletSecurityConstraintHandler.java:59)
at io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:60)
at io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:77)
at io.undertow.security.handlers.NotificationReceiverHandler.handleRequest(NotificationReceiverHandler.java:50)
at io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43)
at org.wildfly.extension.undertow.security.jacc.JACCContextIdHandler.handleRequest(JACCContextIdHandler.java:61)
at io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:292)
at io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:81)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:138)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:135)
at io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:48)
at io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
at io.undertow.servlet.api.LegacyThreadSetupActionWrapper$1.call(LegacyThreadSetupActionWrapper.java:44)
at io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:272)
at io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:81)
at io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:104)
at io.undertow.server.Connectors.executeRootHandler(Connectors.java:202)
at io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:805)
2020-06-10 11:15:56,612 ERROR [com.apc.sma.client.ExceptionHandlerImpl] (Model Thread 0) Unhandled server error occured. Restarting client. Internal server error SYNCHRONIZE
2020-06-10 11:15:56,707 WARN [com.apc.config.workbench.threads.impl.ExtendedThreadFactory] (Model Thread 0) Exception in thread Model Thread 0
com.apc.config.workbench.OperationAbortedException: Operation aborted
at com.apc.dcoverview.AbstractClientPersistenceHelper.handleException(AbstractClientPersistenceHelper.java:261)
at com.apc.dcoverview.AbstractClientPersistenceHelper$Saver.run(AbstractClientPersistenceHelper.java:155)
Caused by: com.apc.config.hibersync.client.internal.OperationModelClientApplicationException: Server sent an application Exception || threadjobid => {boep8iZnQxGbGPcvvjRtwQ}
... 11 more
Any idea how to troubleshoot this issue will be very appreciated.
Posted: 2020-06-11 04:28 AM . Last Modified: 2020-06-15 01:15 AM
Hi Valentin,
It might be basically caused by an equipment that is located in the rack (such as rack ATS unit), so you might wan to locate the device and remodel it (eg. remove the current model and add a new one originated from the Genome Library).
I will send you an invite to my =S= box shortly so the following data could be safely shared with me (if you would):
copy of the backup file
screen captures illustrating which device(s)/rack(s) having the issue and how to produce.
then I will take a look and see what might be the cause. thanks.
Kind regards
Posted: 2020-06-15 09:46 AM
Thank you Jef!
I ask customer for backup, but due to security requirements it may take a long time.
I'm not sure if this related to rack installed equipment, because it also happens with empty racks.
I'll investigate it and will be back with results
Posted: 2020-06-16 12:06 AM
Hi Valentin,
If it happens with empty racks, then I guess (only guessing) it might be related to something in the rooms power path or perhaps related to the Genomes device itself. If it should be Genomes device related (eg. old/modified device in users Genomes), then try a device from the Genome Library.
Kind regards
Posted: 2020-06-22 01:41 AM . Last Modified: 2020-06-22 01:42 AM
Hi!
New issue - client crashes when we trying to import equipment via Excel.
2020-06-22 10:18:21,053 WARN [com.apc.config.workbench.threads.impl.ExtendedThreadFactory] (Model Thread 0) Exception in thread Model Thread 0
java.lang.IllegalStateException: The command [InsertEquipmentIntoEquipmentWithUPosCommand] has already been executed!
at com.apc.config.commands.AbstractGenericCommand.checkIsExecuted(AbstractGenericCommand.java:37)
at com.apc.config.commands.AbstractGenericCommand.executeWithProgress(AbstractGenericCommand.java:61)
at com.apc.config.commands.CompositeCommand.executeWithProgress(CompositeCommand.java:89)
at com.apc.config.undo.internal.services.UndoService$7.run(UndoService.java:509)
at com.apc.config.workbench.threads.impl.wrappers.RunnableWithProgressWrapper.run(RunnableWithProgressWrapper.java:22)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
2020-06-22 10:18:21,068 ERROR [com.apc.sma.client.ExceptionHandlerImpl] (Model Thread 0) Unknown error occured. Restarting client.
2020-06-22 10:18:57,056 ERROR [com.apc.sma.client.Application$EclipseToLog4jLogListener] (main) Unhandled event loop exception [org.eclipse.core.runtime]
Posted: 2020-06-22 02:48 AM
Hi Valentin,
Log records complaining about the illegal state exception and saying also the insert command has already been executed.
By the way, it would be great to start with a new post (for new issues) 🙂
Kind regards
Posted: 2020-06-22 04:04 AM
Thanks Jef!
I will create new post next time 🙂
I add this entry because it is the same customer and desktop client still crashes, but this time it caused by Excel import.
What can cause several executions of insert command? User press Finish button just once, DCO fill rack with equipment and close.
I can't reproduce this on second workstation. I have tried to import the same file and it was uploaded without any problems.
I recommend to clean .isxo folder under user profile. What else we can recommend to the customer?
Posted: 2020-06-22 04:17 AM
Hi Valentin,
You are most welcome,
If you are unable to reproduce on another workstation, then it might be something with the users client temp files (or what user have/had been doing before the last operation). So I agree with your suggestion, it makes sense to clear the clients temp files or even reinstalling the client software.
Kind regards
