We Value Your Feedback!
DCE SSL Error after changing Hostname
  • EcoStruxure IT forum
  • Re: DCE SSL Error after changing Hostname
Cory_McDonald
Admiral Cory_McDonald Admiral
124
Jef
Admiral Jef Admiral
110
gsterling
Captain gsterling Captain
71
APC_Steve
Captain APC_Steve Captain
63
Back to EcoStruxure IT forum
sesa241642
Ensign sesa241642 Ensign
Posted: ‎2022-01-11 06:40 AM
647
Hi Community,
DCE used to be perfect. Changed hostname and SSL Error while logging in. Cannot log in. Neither to the web client. Nor the integration seems to be working at ITA end.
SSL Certificate is standard.
No AD authenticated.
New hostname is NOT DNS registered yet.
What can be a possible cause?
  • Data Center Expert
Reply 1
Cory_McDonald
Admiral
Posted: ‎2024-05-03 03:30 AM
Hi @sesa241642,
I'm assuming that this situation was resolved a while ago, but wanted to comment for others if they find this post.
If a self-signed certificate was being used the system should have regenerated a certificate upon the reboot of the hostname change.  If it was a self-signed cert I would have recommended that you reach out through technical support to investigate the issue and get the system back online.
If a custom SSL certificate was imported for use on the server, I would suggest temporarily switching back to a self-signed certificate before changing the hostname.  This will allow you to go through the CSR process again with the new Common Name (CN) using the new hostname.
As always, if the server is offline after performing an action, please reach out through technical support for resolution of the issue.
Cory
This is a heading
