what 4-20 ma sensor configurations are supported?
EcoStruxure IT Forum
  • Re: what 4-20 ma sensor configurations are supported?
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 10:56 PM . Last Modified: ‎2024-04-04 02:43 AM
1241
My customer has NetBotz 450 and wants to add a 3rd party water level sensor to it using the NetBotz 4-20 ma inputs.  They would also be powering it with the NetBotz 24 VDC supply.
  1. From the sensors wiring diagram, I assume it would be a 3 wire configuration, is that supported/tested?
    1. I assume it would be wired like this, correct?
  2. Is there a distance limitation on the power supply cable?
  3. I know how to configure it on the NetBot itself using the external ports, but is there anything else I need to know?
(CID:134028437)
  • NetBotz
Replies 4
DCIM_Support
DCIM_Support Mentor
Mentor
1241
Hi Andrew,
I've no documentation on wiring the current offering with a 3 wire config but if it's anything like the old 4-20 sensor pod, what you've drawn out looks similar to the 3 wire config in it's install sheet on page 4:
Corrected link:
http://www.apc.com/salestools/ASTE-6Z5S7S/ASTE-6Z5S7S_R0_EN.pdf
I'll check with engineering to see if this config has been tested directly on the current models.
(CID:134028667)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
Thanks Steve,  Yup, I used the old 4-20mA pod manual as a reference for it, but wanted to double check since I couldn't find any current documentation either.
I also remember there being some caveats to trying to use it.  IIRC, one of those was regarding using an external power supply, but this config should take care of that.
Thanks again for checking with engineering, let me know when you can.
(CID:134028680)
DCIM_Support
DCIM_Support Mentor
Mentor
Hey Drew,
I can say that I'd seen issues in the past with the pod and using an external power source and similarly, I didn't think it relevant since your drawing was using the local source but that was about the only caveat I thought of as well.
(CID:134028685)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 10:56 PM . Last Modified: ‎2023-10-22 09:38 PM
