dco rest api _ asset creation
Select a Country
  • dco rest api _ asset creation
Cory_McDonald Champion
159
Jef Leader
114
gsterling Mentor
77
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 03:14 PM . Last Modified: ‎2024-04-05 12:40 AM
2162
I've to create a new asset in DCO using rest api using post request
/assets/{asset-id}/children.
How can I define a new asset_id?
I've to create asset in a specific room (I've a roomId), but with api I can specify only xCoordinate, yCoordinate or rackMountPosition.
Could you give me some examples of asset creation?
thanks
(CID:129406530)
  • Data Center Operation
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 03:15 PM . Last Modified: ‎2024-04-05 12:40 AM
2161
Hi Lucama,
Many thanks for the nice details - It is reproducible, but unfortunately not supported.  Currently we do not have supported REST api to add equipment to a room (data center or storage room). As described in the implementation notes, currently rack-mounted equipment can be added via the api (similar to current web client functionality):
If you wish, I can capture a feature request for you. You are also most welcome to post one here: Feature requests
Kind regards
(CID:129411047)
Replies 11
DCIM_Support Mentor
Mentor
could you give me any suggestions?
thanks
(CID:129407978)
DCIM_Support Mentor
Mentor
could someone give me any hint?
I've to create a new asset in DCO using rest api, and I 've tried to use parent asset id, but it doesn't work.
could you give  me some examples?
thanks
(CID:129409809)
DCIM_Support Mentor
Mentor
this error has been returned :
"code": 100108,
"message": "Adding assets to this asset is not supported",
when I try to create asset via api: POST /assets/{asset-id}/children.
While I can create asset in same position using DCO desktop ui.
thanks
(CID:129409943)
DCIM_Support Mentor
Mentor
Hi lucama, thanks for posting. Let's hope you find your answer here.
Kind regards Ditte
(CID:129410861)
DCIM_Support Mentor
Mentor
Hi Lucama,
Are your trying to add an asset (such as server) into a rack, or ... Can you please describe the task in detail, thanks
Kind regards
(CID:129410905)
DCIM_Support Mentor
Mentor
Hi Jef.
I've To create a server in our warehouse.
I can using dco gui, but via rest ws I can't.
Our warehouse have these properties:
"type": "storage",
"parentId": "442a7e18-3b3c-4024-afae-6e680be01f91",
"navigationPath": null,
"customProperties": null,
"customPropertyTemplates": null,
"accessType": "EDIT",
"parentType": null,
"name": "Magazzino ED.9",
"installDate": null,
"shape": null,
"clearance": null,
"positionTopLeftX": null,
"positionTopLeftY": null,
"orientation": null,
"cageId": null,
"deviceLinks": null,
"width": null,
"depth": null,
"tileGrid": null,
"area": 0,
"id": "54692dd1-1444-4068-b2f3-17e8183e9d23",
"stage": null
It has two children:
"children": [
"type": "server",
"parentId": "54692dd1-1444-4068-b2f3-17e8183e9d23",
"children": [],
"parentType": "storage",
"name": "TEST_PROVA2",
"installDate": 1521640754268,
"shape": [
"x": 0,
"y": 0
"x": 443,
"y": 0
"x": 443,
"y": 721
"x": 0,
"y": 721
"x": 0,
"y": 0
"clearance": null,
"positionTopLeftX": 0,
"positionTopLeftY": 0,
"orientation": 0,
"cageId": null,
"width": 443,
"depth": 721,
"barcode": null,
"serialNumber": null,
"modelName": "PowerEdge R710",
"manufacturer": "Dell",
"partNumber": null,
"partNumberId": -20,
"weight": 26100,
"description": "Dell PowerEdge R710",
"height": 86,
"rackMounted": {
"unitHeight": 2,
"unitPosition": null,
"rackMountingPosition": "FRONT_MOUNTED",
"shelfMountedPossible": false,
"shelfMounted": false
"powerConsumer": {
"autoUpdatePowerDraw": true,
"inlets": 0,
"powerRedundancy": "N",
"estimatedLoad": 870,
"nameplate": 870
"id": "1303de54-79a2-4412-b6d8-c467bf508c71",
"stage": "EXISTING"
"type": "server",
"children": [],
"name": "TEST_PROVA",
"installDate": 1516285663354,
"shape": [
"x": 0,
"y": 0
"x": 444,
"y": 0
"x": 444,
"y": 723
"x": 0,
"y": 723
"x": 0,
"y": 0
"clearance": null,
"orientation": 0,
"cageId": null,
"width": 444,
"depth": 723,
"barcode": null,
"serialNumber": "123456789",
"modelName": "PowerEdge R720",
"partNumber": null,
"partNumberId": -21,
"weight": 29166,
"description": "test server in magazzino",
"height": 89,
"rackMounted": {
"unitHeight": 2,
"powerConsumer": {
"inlets": 2,
"estimatedLoad": 1100,
"nameplate": 1100
"id": "3c3712a7-1736-42da-a3df-a95b03d9e77e",
"stage": "EXISTING"
that are servers I've created via DCO Desktop Gui.
Trying to create another server here via POST
curl -X POST --header 'Content-Type: application/json' --header 'Accept: application/json' -d '{
  "genomeId": "ddbfb9ba-0dfb-4406-86c2-a5fae330d12d",
  "rackMountPosition": "FRONT_MOUNTED",
  "xCoordinate": 0,
"yCoordinate": 0
}' 'https://10.4.4.32/api/v8.1/assets/54692dd1-1444-4068-b2f3-17e8183e9d23/children'
I've this error back:
{ "code": 100108, "message": "Adding assets to this asset is not supported", "details": "54692dd1-1444-4068-b2f3-17e8183e9d23" }
thanks
(CID:129410931)
DCIM_Support Mentor
Mentor
2162
Hi Lucama,
Kind regards
(CID:129411047)
DCIM_Support Mentor
Mentor
Thanks Jef for your help.
I'll create a feature request about this item.
To bypass problem I've created (via desktop DCO UI) a generic Rack ("type": "rack") in our storage room, a now I'm trying to create here a server using same rest api and parameters.
But It seems I've same problem : Adding assets to this asset is not supported
thanks
luca
(CID:129411065)
DCIM_Support Mentor
Mentor
this is  my request curl -X POST --header 'Content-Type: application/json' --header 'Accept: application/json' -d '{
  "rackMountPosition": "TOP_MOUNTED",
  "uPosition":0
}' 'https://10.4.4.32/api/v8.1/assets/94fa783e-ddca-4739-93c6-1bc7060e5deb/children'
where 94fa783e-ddca-4739-93c6-1bc7060e5deb is the new rack created id.
But I've same response:  Adding assets to this asset is not supported.
any hint?
thanks
(CID:129411082)
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 03:16 PM . Last Modified: ‎2024-04-05 12:40 AM
Any hint about this problem?
I'm trying to create this kind of server:
"type": "server-genome", "id": "ddbfb9ba-0dfb-4406-86c2-a5fae330d12d", "description": "Dell PowerEdge R720", "manufacturer": "Dell", "partNumber": null, "modelName": "PowerEdge R720", "width": 444, "height": 89, "depth": 723, "weight": 29166, "mountTypes": [ "RACK_MOUNTABLE" ], "unitHeight": 2, "nameplatePowerDraw": 1100
in a generic rack:
"type": "rack", "parentId": "54692dd1-1444-4068-b2f3-17e8183e9d23", "children": [], "navigationPath": null, "customProperties": null, "customPropertyTemplates": null, "accessType": "EDIT", "parentType": "storage", "name": "", "installDate": 1521812796923, "shape": [ { "x": 0, "y": 0 }, { "x": 600, "y": 0 }, { "x": 600, "y": 300 }, { "x": 0, "y": 300 }, { "x": 0, "y": 0 } ], "clearance": null, "positionTopLeftX": 0, "positionTopLeftY": 0, "orientation": 0, "cageId": null, "deviceLinks": null, "width": 600, "depth": 300, "barcode": null, "serialNumber": null, "modelName": "Generic Rack", "manufacturer": "Generic", "partNumber": "GEN_RACK", "partNumberId": -308, "weight": 10000, "description": "", "height": 300, "availableUHeight": 6, "maxWeight": 15000, "ductHeight": 0, "ductToCeiling": false, "designPowerLimit": null, "floorMounted": {}, "positionsOrderFromBottomToTop": true, "positionsCountedFromZeroIndex": false, "id": "94fa783e-ddca-4739-93c6-1bc7060e5deb", "stage": "EXISTING"
but this is the response:
Could you give me any hint?
thanks in advance
(CID:129411566)
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 03:16 PM . Last Modified: ‎2023-10-22 04:30 AM
